Like Tree5Likes
Old 06-20-2012, 08:48 AM   #151
Default Serpent Edit Set-up Sheet??
Someone needs to inform Serpent that their download edit set-up sheet is incomplete. When you click on the spring color it checks numerous colors, cannot put a number value in the suspension tow adjustment inserts, missing neg camber option for the front. Hopefully a Serpent driver sees this posting.
WWW.IGTHOBBIES.COM - Your #1 GT Source!!!
Serpent Cobra GT / OS Speed / Sweep Tires / KO Propo
chaderick is offline   Reply With Quote
Old 06-21-2012, 11:13 PM   #152
jasoncb's Avatar
Trader Rating: 52 (100%+)
Originally Posted by jedijawa View Post
Folks, has anyone been sharing setups? I am setting up for a very tight track and would love to hear where others have found success.
For the very tight track I have found the following to help:
Springs: included yellow and purples in the kit in the prescribed locations
Shocks: #11 piston in the rear and #13 in the front with 80# in the rear and 60# oil in the front
Zero toe
30K diff front 10K diff rear
#6 inserts on toe and castor in the rear, #0 inserts on the front for both as well
Zero droop in the front, 4mm in the rear
The car is turning really well except for a slight off power push.
Anyone else learning how to set this car up well for tight turning?
Thanks in advance,
-Adam
Get the 10 degree caster blocks and that will help with tight tracks and your off power push.
Jason Beam
XB8e'17|XB8'17
Thanks to my sponsors:
RCAmerica, Xray, JConcepts, Hudy
jasoncb is offline   Reply With Quote
Old 06-21-2012, 11:34 PM   #153
Julius's Avatar
They are aware now. Thanks for the heads up.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 06-22-2012, 07:46 AM   #154
Got it! Thanks!
jedijawa is offline   Reply With Quote
Old 06-22-2012, 02:00 PM   #155
Speyederjedi's Avatar
The Cobra GT is ready for the track!!! Now, just have to find time to get to one!!!!
Serpent Cobra GT-serpent-cobra-gt.jpg   Serpent Cobra GT-serpent-cobra-gt-pic-2.jpg
Schumacher Mi5/Serpent Cobra GT
Novarossi Kappo Rally .21/Novarossi Kangaroo .21
Airtronics M8/Spectrum
SWEEP Tires
Speyederjedi is offline   Reply With Quote
Old 06-25-2012, 12:08 AM   #156
theerm's Avatar
why do serpent recommend to put fuel line on the acceleration side of the throttle activating wire?
theerm is offline   Reply With Quote
Old 06-25-2012, 05:45 AM   #157
gashuffer's Avatar
Trader Rating: 48 (100%+)
To reduce slop in your linkages.
T-Sal
gashuffer is offline   Reply With Quote
Old 06-25-2012, 09:55 AM   #158
Julius's Avatar
It's Part a buggy thing. With buggies when at full throttle the fuel line prevents the linkage binding or overpowering the servi when the chassis flexes.
Not really needed in on road but an insurance...
Old 06-26-2012, 05:27 AM   #159
theerm's Avatar
Thank you Julius. I will be able to sleep tonight, I could not work it out. My brain hurt lol.
One more Question you may be able to help me with. Why do we put the 3mm set screw in the side of the rear upright and the side of the front steeringblock? ??
If You Can Help Me I Will Buy You A Beer. cheers mate.
I love my gt cobra
Old 06-26-2012, 12:33 PM   #160
Gonzo RR's Avatar
I love my gt cobra
I was wondering the same thing....
Xray NT1 '08 /'09 EC LRP12R / Serpent 720 '08 RB Concept V12, R3 RB mods, V12 Rody, Matrix RW / Serpent 733, 733TE RB T9 / EA RC8T OS .21 Vspec speed tuned / Kyosho Inferno GT, GT2 / EA SC10 / Serpent Cobra GT coming soon!
Gonzo RR is offline   Reply With Quote
Old 06-27-2012, 08:28 AM   #161
I love my gt cobra
There are a couple of areas that require these set screws, the reaason being to keep the pins and bearings in place. Be careful with the ones for the bearings. If you tighten them too much they put pressure on the bearing and that in turn puts pressure on the wheel shaft which will not allow the car to roll freely.
SWEEP Tires
Old 06-27-2012, 08:56 AM   #162
Hey guys what body seems to be working on this car?
-C
austindiver is offline   Reply With Quote
Old 06-27-2012, 09:17 AM   #163
-C
IMO the Protofrom PF8 is a good all around body for this class. The rear wing gives the car plenty of rear plant while the front deflector gives the car plenty of steering. I've also run a Porsche 911 body and Ferrari F430 with my Kyosho IGT and they seem to work well with a slight edge on the F430 but that body is really hard to find anywhere. I know there are plenty of other bodies out there including the Warrior and the Alpha bodies but my personal preference has been to stay with a body that looks like a real GT car.
SWEEP Tires
Old 06-27-2012, 10:30 AM   #164
Grenade10's Avatar
Trader Rating: 37 (100%+)
-C
At the Byron's race, A-main cars had the Alpha, Ofna McLaren, Kyosho 911, Warrior and Protoform PF8 ........ All ran quick but the Alpha really fits the car very well.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 06-27-2012, 11:15 AM   #165
Gary NJ's Avatar
I love my gt cobra
It's to keep the hingepins from turning in the blocks/hibs, which will eventually cause the holes in the blocks/hubs from becoming larger, making the hingepin fit sloppy. Since the hingepin can't rotate in the block/hub, it rotates (and eventually wears) the holes in the arms, causing them to get sloppy. However, the arms are cheaper to replace, and are already subject to wear and bending for other reasons, and are considered consumable parts. As also posted, the setscrews also help retain the hingepins. The use of these setscrews is pretty standard on offroad buggies.
Gary - GMK Supply
www.gmksupply.com
Great products. Goofy names.
Gary NJ is offline   Reply With Quote
Sweep Racing Tires 1/8th GT thread SweepRacingUSA Nitro On-Road 788 04-18-2017 05:02 PM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11732 04-22-2016 10:59 AM
2010 Ipanema US GT Nationals September 3rd through 5th JLock Racing Forum 220 11-01-2010 05:05 PM
Tags
serpent 977, serpent cobra
