Like Tree4Likes
Old 06-12-2012, 03:50 PM   #136
flyboi33's Avatar
Originally Posted by jasoncb View Post
I have built a dozen or more serpent kits and I never had any issue with any of them. I'm sure that what happened to you only happens one in a 100,000 kits. Serpent will be more than willing to take care of the problem, I promise you.
If X-RAY built a gt car it would not be half the car that the Serpent is!!
+ 1 I agree with you on that
DEE ROSS
SPONSORS: Serpent America/ Desoto Racing/ Novarossi Engines
Dialed-RC Hobbies / Futaba/ USN
flyboi33 is offline   Reply With Quote
Old 06-12-2012, 04:05 PM   #137
But it would be twice the price
ETC: Serpent 411 Eryx 3.0 |Serpent 411 Eryx 2.0 | Serpent 411 TE | Xray T2 | Tamiya F104 V2
NTC: Serpent Cobra GT | Serpent 811 | Serpent 748 TQ | Mugen MTX-4
Heli's: Align TRex 500 EX | HK 500 x2
modelfan is offline   Reply With Quote
Old 06-12-2012, 07:33 PM   #138
Only issue I had was the diff mesh. I took some advice from some serpent drivers and had no issues. Now I just need to get my setup right. Stock setup has good corner entry, push in the middle, and a little loose coming out of the corner. I definitely like the quality of the kit. I'm really looking forward to driving it in the Byron's Challenge in two weeks.
WWW.IGTHOBBIES.COM - Your #1 GT Source!!!
Serpent Cobra GT / OS Speed / Sweep Tires / KO Propo
chaderick is offline   Reply With Quote
Old 06-12-2012, 07:42 PM   #139
How did you resolve the mesh issue? I have the rear end ready but definitely it is rough. Tried different shimm combinations and left it the best I could.
Thanks.
Cayo71 is offline   Reply With Quote
Old 06-13-2012, 06:55 AM   #140
theerm's Avatar
My rear diff housing had some plastic left over from the casting process. it was touching the outside edge of the diff gear. I ground the excess plastic away and all sweet. There Is a small mistake in the manual re the steering arm mounting hole. at instruction a35. ?
Cheers and enjoy your first race
theerm is offline   Reply With Quote
Old 06-13-2012, 06:58 AM   #141
theerm's Avatar
I have no shims in the front or rear yet . They feel good as they are. Maybe this will change after a drive
Old 06-13-2012, 11:03 AM   #142
Thanks.
I spoke to two Serpent driver's and they said to put the diff in with no shims and run it a few tanks. Once you have run it then go back and shim the diff mesh. My front was smooth originally and my rear felt like there was sand in the case. Once I ran it everything seemed to get better. I'm going to set my diff mesh tonight.
Chad
Old 06-13-2012, 12:00 PM   #143
Chad
Thanks!
Old 06-14-2012, 01:41 AM   #144
Troy Mckune's Avatar
Trader Rating: 38 (100%+)
I have one BNIB if interested.
1/8th Serpent Cobra GT Brand New BNIB
Mckune Design / facebook page / RC America / XRAY / Lunsford Racing
Mckune Design is a custom manufacturer of CNC machined carbon fiber, G10, & composite laminate parts for RC, Aerospace, medical, and high tech industries.
Troy Mckune is offline   Reply With Quote
Old 06-14-2012, 08:30 AM   #145
Default Ran mine for the first time last night
Well I got my Serpent GT Tuesday afternoon and had a race Wednesday evening... so you all know what I did. Stayed up all night and built it so I could retire the trusty IGT immediately.
Wow, what a car! It was a great build, super straight forward and everything went together well. I did have the same ring and pinion mesh tightness that others have mentioned but it was fine, four laps and it was smooth as silk.
I won the first heat, seconded the second and seconded the main. I hadn't even put the car on a setup board. The car turns like a TC, I love it.
So happy with this purchase, I finally love GT racing! Well done Serpent, you rocked it!
-Adam
jedijawa is offline   Reply With Quote
Old 06-14-2012, 05:49 PM   #146
Team Kamikaze's Avatar
Just a reminder that it is still Free Shipping!
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 06-14-2012, 05:52 PM   #147
Default Diff and shock oils
Whats a good starting point for both? And what is the conversion for cst and wt?
triple7s is offline   Reply With Quote
Old 06-14-2012, 09:48 PM   #148
djmorales's Avatar
Send a message via Skype™ to djmorales
Default triple7s
you got to build it an the force will be with you
djmorales is offline   Reply With Quote
Old 06-17-2012, 01:18 AM   #149
Julius's Avatar
Default Cobra GT-E
Testing the Serpent Cobra GT-e at the MACH in Heemstede.
http://www.youtube.com/watch?v=XiXA5...e_gdata_player
http://www.youtube.com/watch?v=6YnTE...e_gdata_player
Out end of July
Edit: fixed links....
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 06-18-2012, 03:25 PM   #150
Default Any setups available for sharing?
Folks, has anyone been sharing setups? I am setting up for a very tight track and would love to hear where others have found success.
For the very tight track I have found the following to help:
Springs: included yellow and purples in the kit in the prescribed locations
Shocks: #11 piston in the rear and #13 in the front with 80# in the rear and 60# oil in the front
Zero toe
30K diff front 10K diff rear
#6 inserts on toe and castor in the rear, #0 inserts on the front for both as well
Zero droop in the front, 4mm in the rear
The car is turning really well except for a slight off power push.
Anyone else learning how to set this car up well for tight turning?
Thanks in advance,
-Adam
Sweep Racing Tires 1/8th GT thread SweepRacingUSA Nitro On-Road 782 12-04-2016 05:09 PM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11732 04-22-2016 10:59 AM
2010 Ipanema US GT Nationals September 3rd through 5th JLock Racing Forum 220 11-01-2010 05:05 PM
Tags
serpent 977, serpent cobra
