Old 08-19-2014, 06:22 AM   #1411
British Menace's Avatar
Originally Posted by Joe Kimble View Post
Hi guys,
I'm working on a T8V3-GT. Pics soon.
For the electric class Joe?
Can I ask .,..... Does the T8V3 chassis have the kick up at the front?
Regards
BM
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 08-19-2014, 06:50 AM   #1412
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by British Menace View Post
Try ...
Hobbies4life.com
evohobbies.com
I use these alot. They should be able to help you out.
Do look out for the V3 and V2 variants on the chassis's. They are different.
Regards
BM
Just so there is no confusion, there is no V2 or V3 variant for the GT car. The V3 pivot system will not bolt on directly but you can easily modify either the pivot blocks or the chassis. easier to modify the RF pivot block. It is a mod worth doing though 2.5* rear toe is optimal in my opinion. Joe has been working on a conversion from the T8V3 and it is no easy task but in the end he will have a legal car for next season and it should be a very good performer. Hopefully the factory will follow suit.
MantisWorx is offline   Reply With Quote
Old 08-19-2014, 07:20 AM   #1413
Joe Kimble's Avatar
Send a message via Skype™ to Joe Kimble
Regards
BM
Hi! No it's nitro GT8. Still haven't decided if I will use my GT chassis or the Buggy one. But I'm almost done modifying the buggy chassis so we'll see.
Yes the buggy chassis has kickup, which is one of the things that concerns me. Team C doesn't have 0 deg hubs.
Serpent America
Sweep USA
RCShox
Joe Kimble is offline   Reply With Quote
Old 08-19-2014, 07:37 AM   #1414
tbo713's Avatar
If you're looking for the GT short chassis, part number T08871, here is a link:
http://evohobbies.com/catalogsearch/...T08871&x=0&y=0
Not for 196 bucks I will buy a new car before I spend that kinda money
tbo713 is offline   Reply With Quote
Old 08-19-2014, 08:16 AM   #1415
Joe Kimble's Avatar
If I don't use my GT chassis I can sell it to you if you want. I'm not 100% sure yet of what I will do but will let you know. It's got scratches on the bottom but I never crashed with it, and it's perfectly flat.
Makes me realize only now: I did all this season with out crashing, not even once. Crazy.
I did bump against other cars a few times though...
Serpent America
Sweep USA
RCShox
Old 08-19-2014, 12:42 PM   #1416
tbo713's Avatar
[QUOTE=Joe Kimble;13477531]If I don't use my GT chassis I can sell it to you if you want. I'm not 100% sure yet of what I will do but will let you know. It's got scratches on the bottom but I never crashed with it, and it's perfectly flat.
I did bump against other cars a few times though...[/
ok let me know
Old 08-19-2014, 01:37 PM   #1417
I can't see it on their site but give
hobbies4life.com
a call. They can be quite a bit cheaper sometimes!
Regards
BM
Old 08-20-2014, 01:56 PM   #1418
Trader Rating: 15 (100%+)
I actually just lowered the price on that...
If you ever feel like I'm overpriced on something, just let me know. When I did the mass upload for Team C parts, most of them are still retail prices, which I can do a lot better pricing than...
Jeff Fowler
Proudly Sponsored by:
www.evohobbies.com
J_Fowler is offline   Reply With Quote
Old 08-21-2014, 05:03 AM   #1419
Hey Joe......
The V3 chassis.
Do you have a way of measuring what the kick up angle is ?
Also ..... I have the top deck battery holder etc of the V3 on my GT car now.
I'm interested in the mods you had to make to the chassis. I take it you had to modify the chassis to take the two speed?
Also.... Is the front steering. Hubs bell crank etc all different on the V3?
Regards
BM
PS: I think Team C are going to be producing 0 degree hub carriers but if they don't...... I will make you some Joe. Although....bdepending on the kick up angle. O degree may not be enough!?
Old 08-21-2014, 01:28 PM   #1420
Joe Kimble's Avatar
Hey Joe......
The V3 chassis.
Regards
BM
HI BM,
Not sure about the kick up, I'd say roughly 10 degrees. It would be awesome to have 0 degree hubs!!! 10 tor 12 degrees total will be perfect.
To fit everything on chassis, I had to move the transmission mount, the engine, and the Radio Tray. Haven't put everything together yet but I got it all ready to be mounted. I had to move things like crazy because the spurs I use are very big. I don't want to use the original gearing with eliptical pinion/ring because I did notice a difference in performance with the straight cut ones. You can now reach those same ratios by simply putting 17/21 pinions on your clutchbell, but it won't be as fast. Last year I had a 17T pinion on there with the stock pinion/ring and there is a noticeable difference. It's really on initial acceleration that you feel the difference.
Not sure if I will put the ball bearing ackerman bar yet since it will require to do some dremeling on it. I'm first going to test the car and if it works nicely I'll fit the RcShox Ackerman bar.
All the other parts are the same.
As soon as I assemble I'll post some pics. And I'll post some videos if possible.
In theory this car should work awesome, I'll try to test it this weekend.
Serpent America
Sweep USA
RCShox
Old 08-22-2014, 04:59 AM   #1421
Hi Joe......
Good work on the new car. Looks as though there's quite a bit of work involved. It will be interesting to see what your assessment of the car is.
We look forward to your update Joe.
Regards
BM
Old 08-22-2014, 05:04 AM   #1422
tbo713's Avatar
I am going to order it today
Old 08-22-2014, 08:53 AM   #1423
tbo713's Avatar
Does anyone knows the part numbers for the center drive shafts for the short chasis and the part numbers for the braces
Old 08-22-2014, 09:30 AM   #1424
Joe Kimble's Avatar
I'll have a look in a bit and let you know.
Old 08-22-2014, 09:34 AM   #1425
Joe Kimble's Avatar
Default team C T8 V3-GT
So I fitted everything on the chassis but the weight balance is no good. I had to move the radio tray so far to the right that the car is not balanced at all. To compensate I would have to add too much weight on the left side. It would do an awesome oval chassis though! Lol
So I ended up modifying the GT chassis to fit the V3 radio tray and toe plates. I cutoff the rear extention of the chassis, like it is on the V3 chassis. Balance is good too. I'll post pics in a bit
Micro On Road & 1/18 Off Road Nats Thread RCMadness Micro and Mini Scales 1165 12-15-2013 03:49 PM
Team TTC GT-4 Singapore R/C Racers 7281 12-24-2010 08:45 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
