Old 01-09-2013, 05:32 AM   #106
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by C@T View Post
There should be different springs available from Team C also. At least the manual for the GT8LE does show them. The part numbers are T0850/T0852 for the soft ones (front/rear), and T0854/T0856 for the harder ones. The problem is that those part numbers seem to be wrong, may be offraod parts ?
I did measure the set coming with the GT8LE kit and got the following results:
front: 20 lb/inch, length: 37.5 mm (unloaded) ; rear: 16.8 lb/inch, length: 48 mm (unloaded)
@ MantisWorx: Can you please tell me the unloaded length of the Setpent springs.
What diameter of swaybars you are using in your current setup ?
This is great information!! it now makes sense that the stock springs are too soft which is what i suspected.
The Serpent length is 1.5"
Serpent Rear:
Stock RED=18lbs
purple=21lbs
Stock front yellow=29lbs
white=31.5
silver=34.5
black=37.5
Currently i am running stock sway bars but have the optional in my box. Up until now i was running the stock soft springs so had to use the thick stock ones all the way around . Now that i have spring options I may be able to soften the bars up especially in the front, which is the thickest available bar, actually both of them are the thickest and the front is thinner than the rear.
MantisWorx is offline   Reply With Quote
Old 01-09-2013, 05:46 AM   #107
C@T
C@T's Avatar
Found the following list for the Serpent springs:
600597 Spring Fr/Rr Red 811GT 18lbs (2)
600598 Spring Fr/Rr Purple 811GT 21lbs (2)
600599 Spring Fr/Rr Yellow 811GT 29lbs (2)
600600 Spring Fr/Rr White 811GT 31.5lbs (2)
600601 Spring Fr/Rr Silver 811GT 34.5lbs (2)
600602 Spring Fr/Rr Black 811GT 37lbs (2)
Probably you need to loock at the value of the siver one in yours.
Thanks for measuring the length, that helps.
C@T is offline   Reply With Quote
Old 01-09-2013, 06:03 AM   #108
MantisWorx's Avatar
fixed, that was a typo
Old 01-10-2013, 10:49 AM   #109
Trader Rating: 55 (100%+)
Hi all, what is the race ready, dry weight for the Team C? It's pretty hard to get the DM1s below 3700 gms without spending a fair chunk of money. Thanks.
WatchOut is offline   Reply With Quote
Old 01-10-2013, 03:07 PM   #110
I put titanium turnbuckles on my car and a few 4mm alloy screws on the top plate and it came in at just over the 3500. Easy to get that car at race weight.
People spend their lives worrying about death. I'm sliding in broadside h ollering "Wow, what a ride"
spooky 1 is offline   Reply With Quote
Old 01-14-2013, 05:43 PM   #111
MantisWorx's Avatar
Ready for Homestead!!
The prototype shock towers with Serpent springs are the way to go! Stiffer springs completely changed the car , it is so nimble now and turns on a dime. I also dramatically changed the upper camber links and am very happy with the results, will probably offer a kit once this race is over with. One thing i did discover after setting the car up on the station is that with the rear toe spacers in the middle the car has 7* of toe in???? I had to modify the spacers to go in as far as possible and still could only get down to 3.5*, with the chassis being so long 2* would probably be optimal.
Last time out i tested:
custom front shock towers front shock mounts are 3mm taller to accommodate the Serpent springs
Custom rear shock towers, shock mount points are 100mm shorter to accommodate short springs and short shocks (fronts all the way around)
3x1.6mm shock pistons with 1000w oil
+1mm hexs in front and +2 rear
Before, the car was fast but never planted and always rotating especially on exit, this makes it hard to drive in traffic or in a battle so my goal was to increase grip on both ends and the combination works!
Old 01-14-2013, 06:43 PM   #112
Pit-racer's Avatar
Is that an alpha+.23 ?
www.igthobbies.com / Serpent Cobra GT / 748 TQ / Serpent Eryx 3.0 / Desoto Racing / Veytrex.com / JZRacing / Flo-Control
Pit-racer is offline   Reply With Quote
Old 01-14-2013, 06:53 PM   #113
MantisWorx's Avatar
OS speed XZ-R with ALpha head. the small heads dont cool very well with full bodies.
Old 01-14-2013, 06:55 PM   #114
Pit-racer's Avatar
Thumbs up
Kool , let me know how it goes over there at the race. I'm tossed between the snake and the C car.
Old 01-14-2013, 06:57 PM   #115
MantisWorx's Avatar
Its going to be an EPIC battle!!
Old 01-14-2013, 07:00 PM   #116
Pit-racer's Avatar
Yes it will be , hate that I'm gonna miss it. Make Texas Proud Make sure to take a b4 and after pic.
Old 01-14-2013, 07:47 PM   #117
MantisWorx's Avatar
I think i am going to pick up a go pro camera with head gear to record the races!
Old 01-14-2013, 08:55 PM   #118
bassman2's Avatar
Thats a great idea Marcus!
Andy Liu "Flyin' Hawaiian"
2015 teams/sponsors:
Serpentamerica/Desoto Racing, Murnan Modified Motors, VP powermaster Fuel, Sweep Racing USA, Speed Passion, BUKU performance products
bassman2 is offline   Reply With Quote
Old 01-15-2013, 06:40 PM   #119
Pit-racer's Avatar
Make you take a pic of FH .... he luvs the camera.
Old 01-17-2013, 09:39 AM   #120
I want to see everything video of this event. Good luck , Andy. Pit racer and I will be cheering from the sidelines.
Micro On Road & 1/18 Off Road Nats Thread RCMadness Micro and Mini Scales 1165 12-15-2013 03:49 PM
Team TTC GT-4 Singapore R/C Racers 7281 12-24-2010 08:45 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
