Old 03-22-2014, 04:25 AM   #1156
Joseph16's Avatar
Originally Posted by tonylunatic View Post
I Agree.... Your bodies last months because they don't ever get used....
See you soon Pit
I do use alphas bodies and i have to say that i use 2 bodies per season wich is really good. (Not including the Panamerican).
See u in texas for the novarossi challenge!
Serpent America & Desoto Racing.
Picco - Arrowmax.
PT RC Racing Oils.
Neal Smith Mods.
Alpha Tires and Body.
Joseph16 is offline   Reply With Quote
Old 03-22-2014, 06:20 AM   #1157
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Guys , I didnt literally mean a month!
The bodies are very thin, thats just a fact. If you alternate between two you can definitely make them last. but they are nowhere near as durable as the new Serpent RTR body, Protoform or Kyosho.
MantisWorx is offline   Reply With Quote
Old 03-22-2014, 06:27 AM   #1158
Hi guys,
I fitted the Buku clutch and ran today, thanks Marcus for the advise smooth and consistent
Rob
rptech1 is offline   Reply With Quote
Old 03-22-2014, 06:33 AM   #1159
MantisWorx's Avatar
Originally Posted by rptech1 View Post
Hi guys,
Rob
Best upgrade ever!! Mine lasted the entire season last year!!
Old 03-22-2014, 06:43 AM   #1160
Pit-racer's Avatar
See you soon Pit
Man! I'm getting it from all sides. I'll see the whole gang soon enough.
www.igthobbies.com / Serpent Cobra GT / 748 TQ / Serpent Eryx 3.0 / Desoto Racing / Veytrex.com / JZRacing / Flo-Control
Pit-racer is offline   Reply With Quote
Old 03-22-2014, 07:00 AM   #1161
British Menace's Avatar
Boy. What did you do Pit to get this abuse? :-)
Must be getting close to Nitro season?!
.... unless your down there in Texas with that all year round racing.
Looking foreword to this year with my Team C GT car.
Regards
BM
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 03-22-2014, 07:06 AM   #1162
Pit-racer's Avatar
Thumbs up
They all getting on me for taking last year off! They just miss my ice cold Twisted Tea A-main booster! That year was the best. I'll be bringing new drivers to the class and It'll be even better! Here in Texas Nitro has started and picking up steam.
Old 03-22-2014, 08:51 AM   #1163
Joe Kimble's Avatar
Send a message via Skype™ to Joe Kimble
I ll be shaking down my car today... first practice day of the season. I'm excited.
Serpent America
Sweep USA
RCShox
Joe Kimble is offline   Reply With Quote
Old 03-22-2014, 11:13 AM   #1164
All the best Joe. I hope you have a good day!
Just a quick question.
I'm going to try the new Reds Racing Quatro clutch. Anyone tried it yet in GT?
I'm going to be using it on the new R5r engine from Reds.
BM
Old 03-22-2014, 06:39 PM   #1165
Joe Kimble's Avatar
BM
Hi BM I haven't tried that clutch so I don't know how it feels.
Serpent America
Sweep USA
RCShox
Old 03-22-2014, 06:48 PM   #1166
Joe Kimble's Avatar
First spring day of practice today. The car felt awesome and was ridiculously fast. I think that the ball bearing ackermann bar gives a different angle than stock and the car feels even more balanced out of the corners.
I warmed up with single tanks, did a few adjustments then some 10 to 20 minute runs. The gears feel really smooth and the bulkheads didn't budge. I'll try to do some 30 min runs next weekend but it seems that this configuration is really good.
Serpent America
Sweep USA
RCShox
Old 03-24-2014, 05:18 PM   #1167
Joe Kimble's Avatar
BM I just read on redrc about the Reds clutch that it's designed to decrease wheel spin for offroad. I assume that such a clutch is designed to engage at low RPMs. In GT traction is usually very high because asphalt offers a large amount of grip compared to dirt. It will make the car easier to drive though. But for given track conditions (like lets say a prepped track on a race day) a clutch that engages early will cause your engine to overheat and underperfom, unless you are geared very short.
Hope this helps.
Serpent America
Sweep USA
RCShox
Old 03-24-2014, 05:27 PM   #1168
Joe Kimble's Avatar
For example, the team C stock clutch feels awesome and you can utilise almost the entire powerband of the engine. It allows for a super smooth corner exit. But the stock gear ratio is extremely short (12.36 in first and 9.06 in second) which is why that clutch - gearing combination is good. If I were to use the stock clutch with my current gear ratio the engine would over heat very quickly, causing tremendous loss of power and eventually damage to the engine.
Serpent America
Sweep USA
RCShox
Old 03-24-2014, 05:32 PM   #1169
MantisWorx's Avatar
For example, the team stock clutch feels awesome and you and utilise almost the entire powerband of the engine. It allows for a super smooth corner exit. But the stock gear ratio is extremely short (12.36 in first and 9.06 in second) which is why that clutch - gearing combination is good. If I were to use the stock clutch with my current gear ratio the engine would over heat very quickly, causing tremendous loss of power and eventually damage to the engine.
Yea, first thing i had to do when testing the new gear ratios was tighten up the BUKU clutch, it bogged really bad before the adjustments.
THe reds clutch has two settings on it, not sure what they are though.
Old 03-25-2014, 03:07 AM   #1170
Roberto168's Avatar
Hi Guys, I know Marcus is involved with developing the teamC GT8 and I am really hoping he could help by requesting team C release larger pinion gears. We all have the 17/21 gears but we really need 18/22 pinions!! Mainly in Aus the foam tyres we run are much smaller overall diameter than the rubber tyres, and what make things worse, as they wear down in size the car really looses top speed. It would really give us foam tyre running racers the ability to not have to give the engine a rest at half straight as it feels like it is stuck in first gear. It would also then give us the option to play with spur gears to fine tune gear ratios.
Also what life do you guys give for the one way in the 2 speed transmission. My GT car has run approx 2.5 hours and was just curios to know what life you guys are getting out of the one way.
Great thread guys it really has helped allot
ARC 8.0, Team C GT8, serpent 747
Mx Sim, VRC Pro, Realflight, www.nswrcrcc.com
Roberto168 is offline   Reply With Quote
Micro On Road & 1/18 Off Road Nats Thread RCMadness Micro and Mini Scales 1165 12-15-2013 04:49 PM
Team TTC GT-4 Singapore R/C Racers 7281 12-24-2010 09:45 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
