Old 03-15-2014, 08:07 AM   #1126
Joe Kimble's Avatar
Send a message via Skype™ to Joe Kimble
Notice the little groove on the spacer. That groove goes against the inner ring of the bearing
So the flat part of the spacer goes outside the bar, like this
The included screws go through the bearings, like this
Serpent America
Sweep USA
RCShox
Joe Kimble is offline   Reply With Quote
Old 03-15-2014, 08:15 AM   #1127
Joe Kimble's Avatar
Default Ball Bearing Ackermann Bar
Assembled
The amount of play is now minimal and should stay consistently that way. Stock, most GTs get more and more play in the front end as you run them. So this seems to be a great solution for slop problems.
Serpent America
Sweep USA
RCShox
Old 03-15-2014, 08:27 AM   #1128
Joe Kimble's Avatar
Default Gear Conversion
Before installing your conversion kit, you want to install the optional Pinion/Ring (43/13 straight cut).
One thing to be careful with is the backlash shims. I put one on each side. The center position seems to be the best one. Guys who run the new bulkheads seem not to put backlash shims at all. I don't know, I am still using the old bulkheads. Bottom line is that you want to make sure that your gearmesh in there is good, and that the diff housing/ring are not moving left and right more than a hair (ok maybe 2 hairs).
Here is a photo of what comes in the kit
All the items, original parts and RCShox parts combined
First you put the lower part of the transmission mount on chassis, with the 3mm spacers under, like this:
Then you install the top, like this
Serpent America
Sweep USA
RCShox
Old 03-15-2014, 08:28 AM   #1129
Joe Kimble's Avatar
Default Radio tray
Here are some pics of the radio tray, before and after
Serpent America
Sweep USA
RCShox
Old 03-15-2014, 08:30 AM   #1130
Joe Kimble's Avatar
With all installed on chassis
Serpent America
Sweep USA
RCShox
Old 03-15-2014, 08:37 PM   #1131
Rockin G's Avatar
Hey guys, can you tell me of a good alternative for set up station for the GT8 other than Hudy? I realize Hudy is probably the best one out there, but right now, they are made of unobtainium as far as I am concerned. Looking for one that includes Toe and droop blocks and gauge for our cars.
Unsure of Integy quality and quite frankly...their website is confusing and rather vague, so I wouldn't know which one to even get.
Also have heard about TeamMagic...but where and how much?
Thanks fellas.
Rockin G is offline   Reply With Quote
Old 03-16-2014, 03:30 AM   #1132
Thanks fellas.
I have one made by Team C that I've been using for a few years now. I purchased it from my LHS. Hopefully Marcus or one of the other Team C dudes can get you a place to buy one.
TerribleTy is offline   Reply With Quote
Old 03-16-2014, 12:03 PM   #1133
Joe Kimble's Avatar
Last thing I forgot to mention, you gotta make a small round groove in the post that holds the tank so the clutchbell first gear pinion doesn't rub against it.
Serpent America
Sweep USA
RCShox
Old 03-16-2014, 12:29 PM   #1134
san.'s Avatar
Trader Rating: 59 (100%+)
Where can I find the front and rear low profile arm stiffeners/brace?
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 03-16-2014, 03:28 PM   #1135
MantisWorx's Avatar
Trader Rating: 28 (97%+)
What are those??
MantisWorx is offline   Reply With Quote
Old 03-16-2014, 03:50 PM   #1136
MantisWorx's Avatar
TeamC domination at the first annual brownsville brawl! Car was awesome, set TQ each round and during the second round was.009 from running 19 laps. During the main i was the only car in the 15's! had a mishap into a barrier and knocked something loose slowing me down and then the computer crashed so i ended up taking home 2nd place, at least a had a little bit of good luck this time My 8yr old TQd sportsman class and took home the win, i was a proud daddy yesterday, the boy was on fire! I told him if he won i would get him a TeamC
Shout out to Paolo for the TOP deal, engine has been rock solid, i barely ever touch it!! It has over a gallon on it and you still cannot spin it over, super tight!
Old 03-16-2014, 06:16 PM   #1137
Nice! Always fun to see your kids go out and do you proud. Sounds like its time for you to pay up You running the 7 port Top? I've seen and heard great things from this motor. Get that Team C dialed we have a new chassis and crew in our class!
Old 03-16-2014, 07:34 PM   #1138
FastPete's Avatar
Trader Rating: 44 (100%+)
Great job!
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 03-16-2014, 10:31 PM   #1139
MantisWorx's Avatar
I am running the 9 port 21+,
The team C is super dialed I have one of the X3 BNIB you want to buy it?My 8 yr old will demolish it in a matter of a day!
Originally Posted by FastPete View Post
Great job!
Thanks!
Old 03-16-2014, 11:48 PM   #1140
I'm not looking for a X3 but I can ask around here. I'll let you know if someone wants it.
Micro On Road & 1/18 Off Road Nats Thread RCMadness Micro and Mini Scales 1165 12-15-2013 03:49 PM
Team TTC GT-4 Singapore R/C Racers 7281 12-24-2010 08:45 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
