Old 02-07-2014, 05:26 AM   #1066
Did any brand make clutch bell with 15/19 can fit our car?
bestlap is offline   Reply With Quote
Old 02-07-2014, 08:57 AM   #1067
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Not that i know of, i am sure you can rig something up but off hand i dont know!
One step closer!! from a dream:
To reality!
Paolo sent out my new power plant which should arrive today, so if the weather holds up i should have some feedback really soon. I will have it completely assembled with pics by tomorrow.
MantisWorx is offline   Reply With Quote
Old 02-07-2014, 10:04 AM   #1068
scary_jerry's Avatar
Default 15/19 clutch bell
Is there some reason you can't use the HPI Savage bell with Kyosho 15 and 19 tooth pinions ?? The hold-up is usually just getting enough shims on the crank before the flywheel and maybe having to radius the engine side of the adjacent trans mount for clearance of the bell. You guys use the 'mod 1' gears don't you ?? The early Kyosho GT pinions had no 'spacer' between them but the newer GT2 '2 shoe' trans has a spacer between the pinions for the new gap in the trans gears. 'Stuff and Mod' at your discretion !!
I tried to find a picture of your TeamC bell and thought that 'futile', it's easier to pull teeth !!
scary_jerry is offline   Reply With Quote
Old 02-07-2014, 11:48 AM   #1069
Joe Kimble's Avatar
Send a message via Skype™ to Joe Kimble
The OFNA clutchbell takes 15-19. But that still would give too tall of a ratio with the stock spurs. With stock ring pinion it gives a waaay too short ratio (very high numbers we're talking in the 13s and 14s)... With 14-17 or 14-18 the motor becomes way too close to the centerline.
The best solution is making bigger spurs...
Serpent America
Sweep USA
RCShox
Joe Kimble is offline   Reply With Quote
Old 02-07-2014, 01:40 PM   #1070
Default Ah Hah !!
Thank you for that explanation Joe !! I wasn't aware of the driving force for Marcus's campaign on these new gears and trans top plate.
Old 02-07-2014, 02:22 PM   #1071
Joe Kimble's Avatar
Lol no worries. Marcus and I have both intensively been testing. No harm intended...
Serpent America
Sweep USA
RCShox
Old 02-07-2014, 06:14 PM   #1072
MantisWorx's Avatar
Well, its all fitted! in the morning i am going to install the new R/P's. Weather is looking bad for monday so not sure when i will get to the track.
I had to make a new servo plate to move the servo outwards a few mm to keep it from hitting the 1st gear spur. So the tally for parts to convert is:
  1. 3mm transmissioin spacers
  2. transmission cover
  3. servo plate
  4. 3mm servo plate spacers
  5. billet gears
  6. 43/13 ring and pinion
Out of curiosity how many are interested in the kit? For obvious reasons i cant make 1 or 2 at a time and it be affordable. If i can get 10-15 pre-ordered i will make 25 and sit on a few. I have not figured out a price for the custom parts yet, gears will be the same price as before. The only other snag is the rear fuel tank mount touches the small pinion so i notched it and it works fine but no way i can really make anything to fix it. The linkage to the carb actually feels better now, i think the raised servo lines it up better.
I will begin cutting carbon fiber in a few weeks and will offer a carbon fiber trans cover and servo plate!
Another item in testing is a "mini" arm brace. On high grip the full arm braces are the best but when grip is less than optimal no brace works best but then you get the typical arm warp and your ride height gets thrown off. These braces keep the arm straight but allow full flex for increased grip!
Old 02-07-2014, 07:36 PM   #1073
Joe Kimble's Avatar
Beautiful. I'm in for a conversion set.
Serpent America
Sweep USA
RCShox
Old 02-14-2014, 05:24 AM   #1074
jpn
jpn's Avatar
Hi guys
About the diff case failures, here is what I have done and has worked for me...
1. I removed the one side of the shield of each bearing holding the pinion, and installed the open sides facing each other.
2. Drilled a hole in the diff case targeted in between both bearings and put a set screw to seal it.
3. Before a day on the track, I remove the set screw and spray grease inside to make sure the bearings are well lubricated before a day's run..
So far I haven't had issues anymore...this may work but be sure all tolerances are ok. I make sure the pinion has no play to move forward or backward as the forward-backward movement will create friction between the helical spur gear...cause heat and melt the cases..
www.casarosario.net
HIROBO EAGLE3 SWM Y.S.91 SR - HIROBO Freya EX2 Y.S.91 SR - HIROBO Turbulence D3 90 O.S.91HZ - HIROBO LEPTON - ALIGN Trex 600N PRO Novarossi C50-H2 - COPTER X V2 - Futaba 12MZH
jpn is offline   Reply With Quote
Old 02-14-2014, 05:44 AM   #1075
Trader Rating: 308 (100%+)
Can you post pic. I make sure my bulkhead is packed with grease. Worked so far.
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 02-14-2014, 06:34 AM   #1076
RoketRdr's Avatar
Originally Posted by jpn View Post
Hi guys
That actually sounds like a good idea. I'm gonna try this. So far with the heat shield I installed it dropped my diff temps from 200* down to 140*. Would really like to see it even lower so gonna give this mod a shot.
TeamC GT8 - REDS R5 - Buku Clutch - RCShox
RC8.2 - Nova +21-4BTT - Buku Clutch
RC8.2e - Tekin T8 Gen 2 1900 w/ RX8 Gen 2 - RCShox
Highly modded Revo
Airtronics MT-4 w/ Radiopost servo's
RoketRdr is offline   Reply With Quote
Old 02-14-2014, 06:40 AM   #1077
MantisWorx's Avatar
Headed to the track for initial testing of the gear conversion. FYI i have only had 2 responses to this conversion kit so its not looking good right now for production.......
Old 02-14-2014, 09:08 AM   #1078
azeroth's Avatar
Trader Rating: 20 (100%+)
i keep watching and reading this thread i like seeing the development but truly why would a person at this point buy one of these when you have to mod the heck out of it to make it work and be able to compete? especially on a car that only has a roar legality for this year? i understand running what you have but if someone was going to buy a new chassis why?
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 02-14-2014, 03:07 PM   #1079
MantisWorx's Avatar
A few points! You dont have to do ANYTHING to the car at all Tony won two events last year with a box stock long chassis car. I ran the season last year with a car that only had pistons, short towers and Ackerman bar and held my own. What you are seeing now is basically my personal R+D which is what The factory wants me to do, difference is that I post and relay information as i go, this is happening with all cars you just dont always see it! There will be a V2 car sometime this year, the quirks that i am working will be incorporated into the new version.
The ROAR rule is not set in stone and after talking to the powers that be, that rule more than likely will not exist. And on top of that who goes to ROAR events anyway, the biggest GT races throughout the year are Homestead and Joliet and they run open rules. If you ever go to a ROAR nitro race you probably wont do it again it is a royal PITA, not fun at all.
I am a racer first and foremost which means i want to win! We are in a "tenths" game where a simple camber change can put you in the A main or top of the B. So if i think Aunt Jemima syrup in my shocks will give me two tenths best believe i will put it in RC racing is all about the upgrades and putting what you like on your car to make it fit you, some like a stock cars some like every piece of BLING they can put on it and most are in between. Aftermarket parts is what feeds my family so it is in my best interest to find things that make cars faster. Plus , I just like doing it!! No cars are perfect out of the box , remember the factories also sell upgrade parts so kits are not designed to be perfect in the first place.
Old 02-14-2014, 03:17 PM   #1080
azeroth's Avatar
LOL SO TRUE
Micro On Road & 1/18 Off Road Nats Thread RCMadness Micro and Mini Scales 1165 12-15-2013 03:49 PM
Team TTC GT-4 Singapore R/C Racers 7281 12-24-2010 08:45 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
