Old 08-18-2013, 06:43 AM   #721
jpn
jpn's Avatar
I will double check the meshing, could have been too tight, metal to metal contact caused too much heat wearing out the gears prematurely
www.casarosario.net
HIROBO EAGLE3 SWM Y.S.91 SR - HIROBO Freya EX2 Y.S.91 SR - HIROBO Turbulence D3 90 O.S.91HZ - HIROBO LEPTON - ALIGN Trex 600N PRO Novarossi C50-H2 - COPTER X V2 - Futaba 12MZH
jpn is offline   Reply With Quote
Old 08-18-2013, 10:11 AM   #722
Joe Kimble's Avatar
Send a message via Skype™ to Joe Kimble
Hey what's up it happened to me after a few races, they had a little over 12 gallons if I remember correctly. I had the shims on the wrong side but I also was using a grease that was too thin and it didn't stick to the gears.
Now I have the two stock shims on the same side as the ring, and I use either copper grease, black graphite grease or black Moly grease. The black moly grease really sticks to the gears. At the state championship 2weeks ago the car ran good during the entire main and there is no sign of wear on the gears post-race.
If your mesh is a bit loose I think the gears will last a bit but will shave down and strip eventually. I think that the grease does make a difference.
You can make sure you don't overtighten the bulkhead screws.
Edit: Another thing I noticed is that it helps to make sure you tighten the diff screws evenly (not too tight, they hold in place really well because they are thin threaded) step by step to make sure the ring is perfectly flat on the diff housing...
Also, when you change the Ring/Pinion I think it's safer to change the diff housing along with it.
Serpent America
Sweep USA
RCShox
Joe Kimble is offline   Reply With Quote
Old 08-18-2013, 05:21 PM   #723
rcwck's Avatar
Default stock helical gears
Hope this can help.
I have 3 stock never been run diff helical ring and pinion sets. They were removed from OFNA's GT-V2 Pro Chassis cars and replaced with the optional high speed straight cut gears. We need the taller ratio for the electric version. They are 43/10(4.30) gears. I assume they are the same as Team C gears. OFN60715 is the part number.
$20 shipped(USA continental) per set. Paypal only.
PM if interested
Crew chief: "It's suppose to work, if not we'll do the complete opposite".
"Team Medicare"
https://www.facebook.com/#!/hobbystopwest
rcwck is offline   Reply With Quote
Old 08-18-2013, 06:36 PM   #724
tbo713's Avatar
Where can I order the high speed gears from because nitro house has had me on the back order list since march
tbo713 is offline   Reply With Quote
Old 08-18-2013, 07:19 PM   #725
MantisWorx's Avatar
Trader Rating: 28 (97%+)
not sure if i can get them or not, i will check.
MantisWorx is offline   Reply With Quote
Old 08-20-2013, 02:31 PM   #726
Jstall7543's Avatar
The car looks sick Marcus! Your really doing it right! I really enjoyed your build series with all the helpful tips. Where are you getting all the team c parts? They are hard for me to find!
RC is a way of life and a ridiculous hobby.
Ridiculously Fun! Subscribe to my YouTube Channel! Or ELSE! Hehee! http://www.youtube.com/user/Jstall7543
Jstall7543 is offline   Reply With Quote
Old 08-20-2013, 02:45 PM   #727
MantisWorx's Avatar
RCShox.com man, i thought you knew!! I have more inventory on hand, took pix today will be up in a couple days!
Old 08-20-2013, 07:25 PM   #728
Jstall7543's Avatar
Ya, I knew. I was just wondering where is a good place to buy parts in general for the gt8l? I can't find anywhere that has everything.
Old 08-20-2013, 08:43 PM   #729
MantisWorx's Avatar
Pretty much me and nitro house, I order pretty much on a weekly basis and am building inventory up but if there is anything in particular you need just email me the part number and i will get it.
Old 08-22-2013, 01:59 PM   #730
MantisWorx's Avatar
The "BEAST" is finally done! engine is broken and and base setup complete, it will be sad to see her go but She is just fulfilling her destiny!!
Waiting on a few odds and ends to be delivered and finish cutting gears! Awesome looking car and somehow after all of the break in and tuning not a single scratch on the car! Thats CRAZY!!
Test mode!
TeamC aluminum steering block
TeamC aluminum rear hub
I am gonna miss her
Old 08-22-2013, 02:44 PM   #731
Trader Rating: 315 (100%+)
What white body is that?
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 08-22-2013, 03:10 PM   #732
MantisWorx's Avatar
the old school Maclaren or TEAMC MT body, same one i have been using , trick is lowering it as low as possible! looks really good low huh?!!
Old 08-22-2013, 06:23 PM   #733
DDG
Nicely said Marcus " She is just fulfilling her destiny " )
DDG is offline   Reply With Quote
Old 08-24-2013, 05:38 AM   #734
Cody_ferone's Avatar
Trader Rating: 12 (93%+)
Can't find these kits anywhere in stock?
Cody_ferone is offline   Reply With Quote
Old 08-24-2013, 05:46 AM   #735
British Menace's Avatar
Try these .....
Rcshox.com
Nitrohouse
Tcmodels.net
There must be others too...... you would have to do a search.
I hope this helps.
BM
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Micro On Road & 1/18 Off Road Nats Thread RCMadness Micro and Mini Scales 1165 12-15-2013 04:49 PM
Team TTC GT-4 Singapore R/C Racers 7281 12-24-2010 09:45 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
