Old 08-03-2013, 05:46 AM   #676
jpn
jpn's Avatar
Hi Marcus,
The weights you posted include the Sweeps, or just the car and body?
www.casarosario.net
HIROBO EAGLE3 SWM Y.S.91 SR - HIROBO Freya EX2 Y.S.91 SR - HIROBO Turbulence D3 90 O.S.91HZ - HIROBO LEPTON - ALIGN Trex 600N PRO Novarossi C50-H2 - COPTER X V2 - Futaba 12MZH
jpn is offline   Reply With Quote
Old 08-03-2013, 06:32 AM   #677
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by jpn View Post
Hi Marcus,
Complete car with Maclaren body, no fuel! The REDS engines are the lightest on the market, 348g for the M7T!
I finished my long chassis conversion last night and i got it down to 3175 w/o body and 3628 complete, the long chassis bodies are heavy but the car now weighs exactly what my short chassis car weighed. So at least we know the long is not handicapped by weight.
TeamC now has aluminum ball ends, shock post, internal dif shafts and some other tid bits which will shave more weight. i would like to get it down to 3600 with the arm braces so i need to find another 75g.
MantisWorx is offline   Reply With Quote
Old 08-04-2013, 09:14 AM   #678
jpn
jpn's Avatar
I removed battery box and installed bat direct on chassis and no more switch. Should be close to 75grams...
www.casarosario.net
Old 08-04-2013, 02:39 PM   #679
MantisWorx's Avatar
Just got home from some R+D and shakedown runs on "Tha BEAST"!! car handles sooooo good! Took some vid I am about to start editing and will post up later tonight.
here is the vid of the MP body on track and my first stab at the long chassis, needs some work but i think the potential is there, track is not prepped, very dusty and tires are old so its a bit loose but looks good on video!
http://www.youtube.com/watch?v=G9Vh-...ature=youtu.be
Old 08-06-2013, 05:45 PM   #680
MantisWorx's Avatar
Those of you that pre-ordered the bodies; they are in transit and i expect them to be in my hands early next week, i will ship ASAP. THE BODIES ARE NOT IN STOCK!!
Old 08-08-2013, 08:39 AM   #681
jpn
jpn's Avatar
How often do you guys check the 3 bolts that hold the 1st & 2nd gear to their respective housings. Every time I check them ther are already at least 1/4 turn loose, on one of my cars that I did not check for quiet some time, the aluminum housings were already damaged...the hole was already oval shaped cause of the play most likely from acceleration and braking
www.casarosario.net
Old 08-08-2013, 10:20 AM   #682
British Menace's Avatar
If you don't check .... it sounds as though we should be doing so!
Thats a good catch and could be the reason for damage and for maybe effecting gear mesh and striping.
Do you loctite the screws when you assemble them?
BM
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 08-08-2013, 12:35 PM   #683
MantisWorx's Avatar
I'm on vacation with the family but will chime in on this tomorrow. Green mixture works good but thin lock nuts work better.
Old 08-08-2013, 03:12 PM   #684
jpn
jpn's Avatar
Would thin nuts with locktite be ok in case I don't find thin locknuts?
www.casarosario.net
Old 08-08-2013, 06:03 PM   #685
MantisWorx's Avatar
Yes, grind off the plastic nipples and use red or green loctite with thin nuts. My gear kits come with new screws and nuts.
Old 08-10-2013, 01:44 PM   #686
Trader Rating: 309 (100%+)
At the NY state championship race. Day 1 during practice GT was running really good, then on my last practice tank diff cases melted. Need to stock up on parts.
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 08-10-2013, 01:54 PM   #687
MantisWorx's Avatar
Been there done that!! the new gear cases do not do that, they changed the material and you also need to make sure there is a gap in between the cvd and the housing.
Old 08-10-2013, 03:00 PM   #688
You have in stock? Love the car otherwise.
Jermaine Mitchell
Mercenary Racer
Old 08-10-2013, 06:07 PM   #689
RoyJ's Avatar
The F/R bulkhead for GT8 is the same as what's used for the T8 buggy/truggy platforms, as well as for OFNA's Buggy8.
Marcus is right in that you must leave a small gap between the outer pinion bearing and the center cvd. Otherwise there will be no room for the steel to expand at operating temperature. That causes overheating, which can result in either your cvd set-screw loosening off the pinion, or deformation (melt-down) of the bearing seats in the plastic bulkhead.
Obviously a bad (dragging) bearing could cause overheating too.
Team C Racing USA, Reds Racing USA, Sidewinder Fuel, Sweep Racing, SMC Batteries, Power HD Servos. TeamcAmerica@gmail.com
RoyJ is offline   Reply With Quote
Old 08-10-2013, 06:45 PM   #690
Joe Kimble's Avatar
Send a message via Skype™ to Joe Kimble
I wish I had spare to give you tomorrow.
Serpent America
Sweep USA
RCShox
Joe Kimble is offline   Reply With Quote
Micro On Road & 1/18 Off Road Nats Thread RCMadness Micro and Mini Scales 1165 12-15-2013 03:49 PM
Team TTC GT-4 Singapore R/C Racers 7281 12-24-2010 08:45 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
