Old 07-25-2013, 05:10 PM   #631
MantisWorx's Avatar
Trader Rating: 27 (97%+)
Originally Posted by DDG View Post
MantisWorx, The sun is up. Me and JPN will be testing the setup you gave me. Will give you feedback ASAP.
Good, i am confused a little on whats going on with your car, i actually ran that setup today on a very loose track and it was very good.....
MantisWorx is offline   Reply With Quote
Old 07-25-2013, 07:26 PM   #632
DDG
I think it has something to do with our track. So far never tried running GT in asphalt but basing it on my 1/10 EP touring, My setup for an asphalt track is totally different from my setup in this track. However JPN will be with me this afternoon and his Team C car is really glued.
DDG is offline   Reply With Quote
Old 07-26-2013, 06:56 AM   #633
jpn
jpn's Avatar
DDG, if we run again tomorrow and your car doesn't work out well yet, lets try swapping out motors for one run...maybe mine does have much less torque thus is more planted on the exit even when heavy on the throttle.
Could that be a possibility MantisWorx?
www.casarosario.net
HIROBO EAGLE3 SWM Y.S.91 SR - HIROBO Freya EX2 Y.S.91 SR - HIROBO Turbulence D3 90 O.S.91HZ - HIROBO LEPTON - ALIGN Trex 600N PRO Novarossi C50-H2 - COPTER X V2 - Futaba 12MZH
jpn is offline   Reply With Quote
Old 07-26-2013, 07:02 AM   #634
MantisWorx's Avatar
Originally Posted by jpn View Post
DDG, if we run again tomorrow and your car doesn't work out well yet, lets try swapping out motors for one run...maybe mine does have so much torque thus is more planted on the exit even when heavy on the throttle.
Yea that is very possible, this car rarely has an exit issue. what engine is he using? and what gears?
Old 07-26-2013, 08:29 AM   #635
jpn
jpn's Avatar
DDG has a Nova Bonito off road. With the stock gears
www.casarosario.net
Old 07-26-2013, 08:33 AM   #636
jpn
jpn's Avatar
I meant mine had much less torque...Thus more planted on the exit...
www.casarosario.net
Old 07-26-2013, 11:44 AM   #637
MantisWorx's Avatar
He needs to put the 45/41 on
Old 07-29-2013, 08:36 AM   #638
British Menace's Avatar
Is there a stronger servo saver spring or is the stock one OK?
BM
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 07-29-2013, 11:31 AM   #639
MantisWorx's Avatar
BM
Stock one is good just make sure you use blue loctite on the threads.
Old 07-29-2013, 01:02 PM   #640
Right ..... thanks Marcus.
One more question ..... what's a good starting point for diff and shock oils for Leisurehours Raceway?
Thanks again
BM
Old 07-29-2013, 03:52 PM   #641
MantisWorx's Avatar
Thanks again
BM
I ran 300/30 at that track with the spider gear shims removed.
Old 07-29-2013, 04:08 PM   #642
Trader Rating: 306 (100%+)
Having problem with 2 speed, shifting too early. When i tighten the adjustment screws it comes out the other end and binds. Do you have to use shorter screws?
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 07-29-2013, 04:31 PM   #643
MantisWorx's Avatar
Hmmmm Well i always grind the head down on a stainless 12mm screw so it doesn not make contact with the bell. but in order for it to go through the other side you would have to drill that hole through???? its is a blind hole so thats a little weird???
Over the next three days ai am doing a build and am going to post up information and tricks along the way starting in a few hours so i will address these things as i go!
Old 07-29-2013, 05:03 PM   #644
pic of screw coming thru.
Jermaine Mitchell
Mercenary Racer
Old 07-29-2013, 05:33 PM   #645
Why do you remove the spider gear shims ..... mesh/ clearance?
BM
Micro On Road & 1/18 Off Road Nats Thread RCMadness Micro and Mini Scales 1165 12-15-2013 04:49 PM
Team TTC GT-4 Singapore R/C Racers 7281 12-24-2010 09:45 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
SEO by vBSEO 3.5.0
