Old 07-11-2013, 06:56 AM   #511
jpn
jpn's Avatar
Thanks for the clutch set up tip MantisWorx ...
www.casarosario.net
HIROBO EAGLE3 SWM Y.S.91 SR - HIROBO Freya EX2 Y.S.91 SR - HIROBO Turbulence D3 90 O.S.91HZ - HIROBO LEPTON - ALIGN Trex 600N PRO Novarossi C50-H2 - COPTER X V2 - Futaba 12MZH
jpn is offline   Reply With Quote
Old 07-11-2013, 07:59 PM   #512
abi787's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to abi787
Default żdroop?
Hey Marcus, to set your DROOP, what blocks and gauges do you
Use for the GT cars.I have 20mm blocks, and Droop gauges #107717-0 to 13mm. and#107711 - 3 to 10mm. (hudy).what's the right combination, in your opinion. Thanks.
Team Modelo<My Rides>Xray T4-14,13/Ofna DM1/Top Photon/Associated RC8bMBX5t brushless/Tamiya M06/Ofna TT
Traxxas REVO/MRX4 brushless/Losi 22sct.
Home Tracks:Ft.Knox Rc Park (RCNYC) Bronx N.Y./
MRRC Raceway Manorville Long Island N.Y.
abi787 is offline   Reply With Quote
Old 07-11-2013, 08:16 PM   #513
MantisWorx's Avatar
Trader Rating: 28 (97%+)
I use the 20mm integy blocks and set the droop to 12mm at the bottom of the outside hingepin front and rear.
MantisWorx is offline   Reply With Quote
Old 07-12-2013, 04:42 PM   #514
scooby61's Avatar
Marcus, is there any where I can get instructions on how to install the 3* toe block and arm stiffeners I just got from you?
scooby61 is offline   Reply With Quote
Old 07-12-2013, 08:32 PM   #515
MantisWorx's Avatar
The toe block installs just like the stock one and will only go on one way.
The arms braces require a 3/32 drill (.093) and are pretty straight forward.
  • lay the brace on the arm (do it with the arms installed on the car)
  • drill one hole and screw it down
  • do the same for the rest of them one at a time
Old 07-13-2013, 12:25 AM   #516
Joe Kimble's Avatar
Send a message via Skype™ to Joe Kimble
Hi! I think the gauges that go with the blocks should have the 0 mark at the same hight as the hight of the block.
Just a little remark concerning the droop gauges. Those things actually give a downstop value, not a droop value. If I am not mistaken the droop is the amount of vertical travel from the ride high position to the point where wheels lift from ground. Indeed the droop has to be set with the downstop screws once the ride high is set, which is why I believe the gauges are called droop gauges.
Serpent America
Sweep USA
RCShox
Joe Kimble is offline   Reply With Quote
Old 07-13-2013, 05:28 AM   #517
MantisWorx's Avatar
Yes this is true, it can be confusing! I rarely mess with droop and in my opinion it is usually used to limit traction on either end. Since this car is flat and GT cars tend to "roll" alot you dont need to be too critical with it. At the byrons event i had to increase droop in the rear on sunday because grip was getting really high and the inside rear tire was starting to rise on the higher speed turns which was making the rear lose traction and spin. This was common with pretty much everyone. I turned the rear droop screws 1/2 turn out and it went away.
Old 07-13-2013, 12:13 PM   #518
scooby61's Avatar
Done thanks Marcus
I'll test these out tomorrow
Old 07-13-2013, 12:40 PM   #519
MantisWorx's Avatar
Done thanks Marcus
Cool, let us know!
Old 07-13-2013, 02:13 PM   #520
tbo713's Avatar
I raced my gtv2 L today and I must say I am selling both my full optioned dm-1s because the gt8l is planted like a slot car TQ'ed and won the Main I got a winner on my hands
tbo713 is offline   Reply With Quote
Old 07-13-2013, 05:33 PM   #521
MantisWorx's Avatar
THATS AWESOME MAN
This is starting to happen alot here lately
Old 07-14-2013, 10:45 AM   #522
jpn
jpn's Avatar
Just wanted to share...
For our local club race top 3 were Team C GT8s. Fastest lap and TQ too. It's a car on rails. Among the Team C cars, lap times were close, a tenth of each other, the other brand cars were about a quarter sec of the pace of the Team Cs. Great racing.
www.casarosario.net
Old 07-14-2013, 03:10 PM   #523
tbo713's Avatar
THATS AWESOME MAN
Does that 3°toe plate come in aluiminum because I just relized mine broke but the car was still stroking
Old 07-14-2013, 03:17 PM   #524
British Menace's Avatar
That is great to hear ......... awesome job.
BM
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 07-14-2013, 03:39 PM   #525
MantisWorx's Avatar
LOVELY!!
WOW, you must have really nailed something hard, if you broke that one you would have bent a stock one. I doubt i will make them out of aluminum, with the TeamC V3 toe block coming out soon (may be out already, i will check) it will be a better replacement piece and will be made out of aluminum.
Micro On Road & 1/18 Off Road Nats Thread RCMadness Micro and Mini Scales 1165 12-15-2013 03:49 PM
Team TTC GT-4 Singapore R/C Racers 7281 12-24-2010 08:45 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
