Old 06-28-2013, 04:33 PM   #436
MantisWorx's Avatar
Trader Rating: 28 (97%+)
small clip of saturady and sunday at Byrons!
http://youtu.be/1FGcfsdFYq8
MantisWorx is offline   Reply With Quote
Old 06-28-2013, 05:01 PM   #437
scooby61's Avatar
Thumbs up
That looked like fun
Wish I.could get my gtv2 dialed in like that.
scooby61 is offline   Reply With Quote
Old 06-28-2013, 07:19 PM   #438
MantisWorx's Avatar
I have a customer in brownsville with a V2 that handles really well, not quite as agile as mine but very good. I actually think i can make a long chassis work good now. My son is about to start racing nitro so i may pick up another long chassis and see how it goes!
Old 06-29-2013, 02:32 AM   #439
scooby61's Avatar
Cool! My son races 10th scale with me. Keep the parts hints coming we all appreciate your help and all that r&d.
Old 06-29-2013, 07:23 AM   #440
Yb2fast's Avatar
You are doing a great job Marcus. Will ofna sell the v2 with the shorter chassis as an option ?
Yb2fast is offline   Reply With Quote
Old 06-29-2013, 07:25 AM   #441
Yb2fast's Avatar
Also I noticed not too many vent holes in UR ofna dp8 body ... Why is that ?
Old 06-29-2013, 04:15 PM   #442
MantisWorx's Avatar
Doubt it, just buy the TeamC version, It will have better parts on it anyway, just like the TS4.
The holes make no difference whatsoever , just make the body weaker!! the entire bottom of the body is open, you only need holes for refill, glow plug and heat measurement. Technically that is the TeamC MT body!! they are all made by Hong nor though!
Old 06-30-2013, 07:41 AM   #443
jpn
jpn's Avatar
Quick question for Markus...
Is it possible to use 45/42 rather than the 46...I want a longer first gear and maintain the 2nd gear ratio due to the nature of our track...?
www.casarosario.net
HIROBO EAGLE3 SWM Y.S.91 SR - HIROBO Freya EX2 Y.S.91 SR - HIROBO Turbulence D3 90 O.S.91HZ - HIROBO LEPTON - ALIGN Trex 600N PRO Novarossi C50-H2 - COPTER X V2 - Futaba 12MZH
jpn is offline   Reply With Quote
Old 06-30-2013, 08:17 AM   #444
Yb2fast's Avatar
Tks for the reply Marcus...So team C sells that Mclaren Body also I would imagine ? ...Thats the body that I use on my Kyosho GT1....Love it....As far as the vents hole go, what kind of eng temps you see on race day ? I would imagine fresh air blowing through the windshield and side windows exiting through the rear window would dramatically cool the head ??
Old 06-30-2013, 08:49 AM   #445
MantisWorx's Avatar
Yes, you can interchange them all
Aerodynamics are a funny thing, i cut the rear window completely out and the engine was hotter, replaced with lexan and temps dropped. since the bottom is completely exposed, you get different pressure drops than what you would think. If the head is not exposed you really dont need a bunch of holes. If you have more air going into the body than can exit you make matter worse. My engines run around 250-270 depending on ambient of course. at the byrons event i was finishing 10min qualifiers at 215*. Things change at 60mph. I actually think you can get better flow by ducting from the bottom but we need a wind tunnel to get it right! You have to match the intake and exit flow or the air will not flow. If you have a large windshield hole and two side holes only to exit through a small hole in the rear then the air will not flow and basically stall. the hole i have in my windshield and the engine hole are the same size.
I am starting to favor the Mt body too I have noticed that the Alpha bodies "tuck" bad and everyone at one time or another had to stop and have a marshall untuck them or pull into the pits to fix it......thats wasted time. The Mt body will not tuck. handling wise i dont feel much of a difference between the two, the Alpha may have better mid rotation but its minimal if at all.
Old 06-30-2013, 09:41 AM   #446
jpn
jpn's Avatar
MantisWorx
Thanks for you set up tips, the GT8 (not me though) won over a field of Cobra GTs here at our local track in Cebu, Philippines...
We were way down on power running SH motors against Cobras with Nova Bonitos, BTTs, Werk, but turn in and corner speed of the GT8 equalized things The way I saw it.
Fastest lap though belonged to a cobra GT/Bonito 17.5sec. The GT8/SH21 though was close enough with a17.7... With much less power ....
www.casarosario.net
Old 06-30-2013, 11:43 AM   #447
MantisWorx's Avatar
MantisWorx
Thats awesome! post up some pix and vid if you have any!
Old 06-30-2013, 02:43 PM   #448
tbo713's Avatar
Where can I buy a short chassis from because I want to convert my v2 to the shorter version for tight tracks
tbo713 is offline   Reply With Quote
Old 06-30-2013, 02:48 PM   #449
MantisWorx's Avatar
I can order one for you but it is expensive and you also need a rear center CVD, chassis braces are the same.
Old 06-30-2013, 05:56 PM   #450
tbo713's Avatar
So you don't keep them in stock
Micro On Road & 1/18 Off Road Nats Thread RCMadness Micro and Mini Scales 1165 12-15-2013 03:49 PM
Team TTC GT-4 Singapore R/C Racers 7281 12-24-2010 08:45 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
