Old 05-22-2013, 01:38 PM   #406
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by TerribleTy View Post
I'm not trying to make a manufacturer war either. In my opinion what you say has to be well thought out as you represent a company. You aren't just some dude on the forum with a stick in his butt you are a representative of Team C to all of us. Your opinions are your opinions but in my opinion should not be part of you representing Team C. You are public relations the guy we get to talk to if something is going great or if something is going bad. Represent Team C with positive statements, the facts will speak for themselves elsewhere. I don't look at you as some dude on a forum that's my problem I know what a factory driver should be like I've met many and continue to be impressed with their plight. Any company will fail with negative promotions this isn't politics.
I deleted the entire Subject, its a moot point..... It is what it is.
Those of you that PM'd me, thank you for your support! Ty if you want to continue this debate PM me and i will give you my phone number. Same with you Gus.
MantisWorx is offline   Reply With Quote
Old 05-22-2013, 03:58 PM   #407
People spend their lives worrying about death. I'm sliding in broadside h ollering "Wow, what a ride"
spooky 1 is offline   Reply With Quote
Old 05-22-2013, 06:32 PM   #408
MantisWorx's Avatar
Originally Posted by spooky 1 View Post
I did the chassis openings for the gears , and not having a machine shop, I used a dremel and it shows. Looks like hell so I hope it works. I'll be trying it tonight at our races with new gears all around. I KNOW the mesh is good now , so we'll see what happens. I didn't want to scar up my chassis that way , but if that's what it takes to make it work so be it. I do have a spare chassis. Changed the one-way, shimmed the steering, dremeled the chassis adjustment area, went to good bearings. I haven't had brake issues as yet so I left the plastic uprights on. Is there anything else I should know about on this car? I do have a question about the gear diameters. With 32 pitch the gears can't all be the same diameter . More teeth equal larger diameter unless you change pitch. Just like your pinions. Please explain.
I Actually dremeled mine but after i did realized that they already address the issue from the factory! Which one way did you use? the issue with the uprights is that as they get hot they get soft and move around. If your track is not hard on brakes then it probably wont be much of an issue.
On the gear thing, look at all nitro 2 speed cars no matter what pinion size you use the Pitch diameter is the same, if it were not you would be forced to only run certain pairs of gears ie you cant change one gear with out changing the other. The difference in pitch diameter from a 41t to a 40t is only .012" not alot but if you go the opposite way with first gear then you have over .5mm difference and that is hard to get a good mesh. So I maintain the same OD and pitch diameter and simply change the teeth angle to achieve the spread. Hope that made sense and hope it didnt piss anyone off
Old 05-22-2013, 07:01 PM   #409
Old 05-22-2013, 10:06 PM   #410
tbo713's Avatar
What's the best way to replace the one way bearing
tbo713 is offline   Reply With Quote
Old 05-23-2013, 07:24 AM   #411
MantisWorx's Avatar
Gather three sockets, 2) 1/4 drive one small and one large and 1) 3/8 or 1/2 drive to set the housing in.
use the small 1/4 to drive the bearing out with a hammer, should only take a few taps, they are not in that tight, make sure you pay attention to the direction the bearing is in , it has to go back in the same way.
use the larger 1/4 drive socket to tap the new bearing in until its flush and you are done!
Old 05-24-2013, 04:51 AM   #412
tbo713's Avatar
Thanks!!! Worked like a charm and know I need to break my motor in
Old 05-27-2013, 02:42 PM   #413
tbo713's Avatar
Do I need the high speed gears
Old 05-27-2013, 03:32 PM   #414
MantisWorx's Avatar
Well there are two ways to go at it, the stock gears are a bit short but the 45/41 set is good for most tracks unless you have a really long straight. the high speed ring/pinion set will run you 84.00 plus shipping. RCShox spur gear set is 35.00 and is 45/40. IMO the high speed ring and pinion suits the electric cars better. I guess it all depends on your specific situation. What engine do you have and what does your track look like?
Old 05-27-2013, 03:56 PM   #415
tbo713's Avatar
I am using the os28 and I plan on racing up blue diamond
Old 05-27-2013, 03:58 PM   #416
MantisWorx's Avatar
I have no idea what track that is but if you are running a 28 and plan on keeping it than i think the high speed ring and pinion will be better for you.
Old 05-27-2013, 04:03 PM   #417
tbo713's Avatar
There seems to be a lot to do to the car to make it competitive and I am still breaking in the motor
Old 05-27-2013, 04:12 PM   #418
MantisWorx's Avatar
Not really, you asked if you needed them And i gave you my opinion! Only thing you NEED in my opinion is the one way and center tranny mount and thats only if you run on a track that demands alot of brakes. Things like gear ratio just depends on your engine. Most dont run 28's we all run 21's which have higher RPM's so the gear set is not needed. Like i said before, i think the gear set is more for the electric version.
hop ups are just that, hop ups! not needed but are nice
Old 05-27-2013, 04:36 PM   #419
tbo713's Avatar
Gotcha but the os 28 has a lot of rpm's but have you considered like a 45,49 combo
Old 05-27-2013, 04:36 PM   #420
tbo713's Avatar
Or even 44,48
Micro On Road & 1/18 Off Road Nats Thread RCMadness Micro and Mini Scales 1165 12-15-2013 04:49 PM
Team TTC GT-4 Singapore R/C Racers 7281 12-24-2010 09:45 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
