Old 05-06-2013, 06:05 AM   #346
MantisWorx's Avatar
Trader Rating: 28 (97%+)
measure the front of the body at the wheels and the rear of the body at the wheels and tell me what the difference is.
I am an official dealer and have painted and installed many of those bodies and have never had this issue. I find it hard to believe that TeamC has sold 1000's of these bodies and yours is the first one to have this issue??
One of the points I think Tony was saying is that i ALWAYS at least set the body down on the chassis to see where the holes and wheel wells will line up. If you did this first how is it that you didnt notice that the wheels would not fit into the body, thats pretty drastic?? Clone bodies use a body for the mold instead of a real mold because they are expensive therefore they are always out of proportion and do not fit.
Writing off the entire brand because of a 30 dollar body and a can of spray paint seems a bit extreme doesnt it? Dude , your car is jacked up, not the body. after looking closely at your picture the body seems to be straight, what kind of chassis is that?Looking at the body post i can tell that it is not a TeamC GT8.
MantisWorx is offline   Reply With Quote
Old 05-07-2013, 07:55 AM   #347
Grenade10's Avatar
Trader Rating: 37 (100%+)
Marcus, here is his original post:
havnt changed anything . This body is a 325-330mm short chassis body . From TeamC that I bought to put on my Ofna GT8 short chassis car. But after going through the process of cutting and painted when I went to mark the body post holes , I couldnt get it to line u cover both wheels then I noticed this god damn thing was to narrow .
Correct me if I am wrong, but the side of the body appears to be the same width in the rear ... along the bottom side and the front ....
If this is correct, the issue is with the front width. You can make the front wider than the rear, but it does not steer or handle well. I normally have my front 3-5mm narrow at the front, which should solve his issue
Keep up the work with the Team C car, I'm working to keep the DM-1 in the mix. I was looking forward to meeting you in Houston, but a knee issue kept me from making the 16 hour drive down. Maybe the Byrons Race, unless you could make it up to Lincoln Nebraska for the Fireball Race Memorial weekend.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 05-07-2013, 08:27 AM   #348
MantisWorx's Avatar
I am moving on from that ordeal, its user error for sure
The DM1 is a good car i tuned about a dozen of them this past weekend in brownsville so many that i would like to R+D some 2 stage pistons and braces for it, If you can send me a shock and/or a chassis with arms attached i will send you some parts to test! let me know. Not sure about Nebraska, my schedule is getting tighter and tighter by the day! Big E coming up in a few weeks, Byrons and the carribean race in the DR that i am trying to make.
We had a Team MERLIN Fuel promo race this weekend in Brownsville TX (6hr drive for us) it was a huge success and we had a blast!
http://www.youtube.com/watch?v=KBWAC...ature=youtu.be
TeamC got TQ and track record with a second in the main!
Old 05-07-2013, 08:35 AM   #349
MantisWorx's Avatar
Old 05-07-2013, 09:23 AM   #350
FLoJo's Avatar
[QUOTE=MantisWorx;12125824]I am moving on from that ordeal, its user error for sure
It really wasnt a ordeal , Or user error , but error on the manufacturer Not trying to get anyone butthurt about their sponsor or brand and I didnt really mean to post it here but this is really the only TeamC onroad criteria I could find on this forum without starting my own post. And if I posted this in paint and bodies section chances are no one would know jack because 99% dont run a TeamC car or havnt heard of it . Just because Im not running it on a teamC chassis doesnt mean my car is jacked . maybe not as tuned as yours but the question was about the body not the car, why I decided to paint it after the fact isnt really the question here either .
Now I did measure the body , I can get technical with 8ths and 16ths but for others that cant measure that way the front measures at right under 11 3/4inches and the rears measure just over 11 3/4 . Personally dont know if they are supposed to be the same or not . But it really isnt a matter of life and death Or about a $30 body and a can of paint which comes out to half of what it really cost me in the end minus prep,paint time and time wasting posting here about it . The only issue I have was I wanted a 1/8scale short chassis 325mm corvette body and even ordered a $15 decal sheet for it .
Yea if TeamC wants to send me a shipping label so I can send it back to them and they can measure to their others ones and if wrong send me a good one not manufacture defect one and give me one that will flare out over my tires then untill then I will not be purchasing anything with the name brand .
I even tried the body on my InfernoGT with stock kyosho wheels and tires which are smaller then alpha slicks and not as bad but still not acceptable . Anyhow it is what it is , not really stressin it as it was my test body to try flat paint on , I bought 3 of them and sold one for what all 3 bodies cost me , so I aint pressed . I just hope theirs are normal and not like mine because Id hate to have unhappy customers . Didnt come in to bash this brand just to see if anyone else had body fitments like I did .
KYoSHo iNFeRNo GT1-E RCMoNSTeR CaSTLe2200 <> KYoSHo iNFeRNo GT2Ve Tekin 2650
oFNa LM DO CaRBoNFiBeR CaSTLe2650 <> TC4 FT
ZDRaCiNG TRuGGy <> HPI NiTRo RS4 .21oS
PRoBoaT STiLeTTo <>TRaXXaS SPaRTaN
FLoJo is offline   Reply With Quote
Old 05-07-2013, 09:45 AM   #351
When will be able to get the gear choices from Team C? I fixed the one-way issue myself, but the gears being limited is making me crazy. I have debated changing to another brand of two speed to have options. they show the gear on their site, but you can't get them. If I have to make too many more one off changes to this car, I may be driving something else soon.
People spend their lives worrying about death. I'm sliding in broadside h ollering "Wow, what a ride"
spooky 1 is offline   Reply With Quote
Old 05-07-2013, 10:08 AM   #352
-R2-'s Avatar
Ok guys today we available the new 43-13 gearing for the differentials the part number is 60836 it is sold as a bevel and pinion gear set, 1 pc each in a bag. You can get them from OFNAWAREHOUSE.COM if you like to purchase right away or go to Nitrohouse.com if you wish to place the order over the phone.
SOAR SEIKI 998,Truggy, Buggy and Electric
Flashpoint Fuel/Savox/
-R2- PAINTS/PRO-LINE RACING/AIRTRONICS
-R2- is offline   Reply With Quote
Old 05-07-2013, 10:48 AM   #353
MantisWorx's Avatar
What gear choices are you looking for? My 45/40 combo will be ready by
By the end of the week and its way more than enough gear for any track! That's what ran in porter on a long track and again this past weekend in A shorter track! I have used it with 5/7/9 port with no issues!
Are you talking about pinions?
I am also running what is essentially a stock car except for spur gears and the rear shock tower which isn't needed at all, I even run stock springs now!
Old 05-07-2013, 06:07 PM   #354
MantisWorx's Avatar
[QUOTE=FLoJo;12126032]
There is nothing wrong with the body, the track width of your car is the issue. Its a TeamC body designed for a Team C car and you installed the body on a car that has a wider track in the front? Why would Team C do anything? If you opened the box on a new Team C kit and it didnt fit , you would have a valid point. I built two kits just last week with that body and it fit perfect, tires may have stuck out a mm or so but that is it. My personal car is 11 7/8 wide with extensions so it would fit that body just fine.....
Old 05-08-2013, 09:32 AM   #355
Marcus, I want those gears as quickly as possible. I'm heading back to L.A. for the KOpropo race and would love to have them. Please let me know how I can order some things from you without using paypal. I'll prepay with cashier check if I have to.
Old 05-08-2013, 09:56 AM   #356
scary_jerry's Avatar
Smile
Is that car actually an OFNA Ultra GP 2E, as hinted by the velcro strap sticking out of side of body and OFNA product site photo showing a wider front track than a rear track????
That would hint to me that it's not actually a Teamc Problem but a 'cross-branding' issue.
scary_jerry is offline   Reply With Quote
Old 05-08-2013, 10:35 AM   #357
MantisWorx's Avatar
I have a set ready to go, fastest way would be to either send a money order or have a friend paypal me and i can send them out tomorrow.
Old 05-08-2013, 04:16 PM   #358
Thanks Marcus, hope to see them soon.
Old 05-08-2013, 05:00 PM   #359
Suspended
Trader Rating: 36 (97%+)
Just Go DM-1 and you will be okay.................LOL
Marcos.J is an idiot along with his side kick's
"And now I'm editing your signature and letting everyone know that you are permanently banned from " your truly Marcos.J aka the idiot
DK McGee is offline   Reply With Quote
Old 05-08-2013, 05:29 PM   #360
Been there , done that.
Micro On Road & 1/18 Off Road Nats Thread RCMadness Micro and Mini Scales 1165 12-15-2013 03:49 PM
Team TTC GT-4 Singapore R/C Racers 7281 12-24-2010 08:45 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
