Old 02-16-2013, 08:06 PM   #151
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by Joseph16 View Post
Way better marcus!!!
A lot of corner speed. Looks like the short chassis is the way to go with team c!
Good luck
yea, its much better lots of fun to drive!
MantisWorx is offline   Reply With Quote
Old 02-16-2013, 08:11 PM   #152
Joseph16's Avatar
I see that!!
I feel happy for you.
Hope to see you in my country in July
Serpent America & Desoto Racing.
Picco - Arrowmax.
PT RC Racing Oils.
Neal Smith Mods.
Alpha Tires and Body.
Joseph16 is offline   Reply With Quote
Old 02-17-2013, 03:22 PM   #153
MantisWorx's Avatar
As promised here is my base setup for the short chassis. There are quite a few parts that are custom and if there is enough interest i can produce them. The car is incredible with this setup on unprepped outdorr permanent tracks or parking lot tracks, this coming weekend the track will have high grip so some changes will be need but i think just adjusting the sway bars should do it, at least thats what i am going to try first.
FRONT:
+1mm spindle extensions
3* camber
2* toe out
10* aluminum caster blocks
Serpent white springs (31.5lb)
Custom sway bar .088"
Roll center in the middle
inside on hub
1200CST with RCShox 2 stage pistons 10x1.3 compression 10x 1.4 rebound
inside on tower outside on arm
Ride height is 8mm
30k Kyosho dif grease
REAR:
+2mm spindle extensions
2* camber
2.5* toe in ( you cannot get this without a custom part, stock settings in the middle are 8*!!!)
Stock antisquat
Stock springs (18lb)
Custom sway bar .078"
Roll center is set inside in the middle/inside on hub
800 CST RCShox 2 stage
outside on tower/ inside on arms
Ride height is 7.5mm
15k kyosho gear dif grease
Ported and polished Novarossi Kangaroo SYDWC 8.5 venturi
nova 9886 pipe with long header
BUKU clutch
45/42 gears
Serpent 2 speed springs turned out 4.5 turns
here is video of the car with these settings
http://www.youtube.com/watch?v=oJpec_0xqZc
Old 02-18-2013, 10:13 AM   #154
C@T's Avatar
What the heck does " +1mm spindle extensions " mean ?
Can somebody explain please.
C@T is offline   Reply With Quote
Old 02-18-2013, 11:01 AM   #155
MantisWorx's Avatar
They extend the width of the car by 1mm on each side, 2mm on the rear.
http://www.teamcracing.net/index.php...mart&Itemid=71
Old 02-18-2013, 11:36 AM   #156
C@T's Avatar
Got it. Just could not translate. Never heard that description.
Old 02-21-2013, 02:55 PM   #157
MantisWorx's Avatar
Southwest series begins tomorrow!
Old 02-21-2013, 04:06 PM   #158
Keep us posted on how things go in the series . Say hey to the Texas bunch for me.
People spend their lives worrying about death. I'm sliding in broadside h ollering "Wow, what a ride"
spooky 1 is offline   Reply With Quote
Old 02-21-2013, 06:17 PM   #159
Jazza's Avatar
Trader Rating: 16 (100%+)
Marcus great vid man of your test day. This body pictured, is that the Alpha body with sweep tires.
And just curious, how many tanks would you get out of a set of tires racing like your test day??
Cheers Darren
Capricorn Lab Co3....Black Edition Co2
Kickass Racing OS Racing Engines RB TXR Engines
Capricorn Racing Tyres....Highest Servo's....VP Racing Fuels
Supporter of Capricorn Australia....Walters Hobbies....JPM Racing
Jazza is offline   Reply With Quote
Old 02-21-2013, 08:00 PM   #160
MantisWorx's Avatar
Cheers Darren
Yes Alpha R3 and sweep 45's
The tires in that last video are the same tires i used in homestead!! I have been running them every weekend since that race and they still are good!! I have over a gallon them now and will run them this weekend at least one qualifier and then i will switch to the new ones just for giggles! Alphas are good for about an hour of runtime and thats being generous!! Luna's car had Alpha's and they around a second slower than the Sweeps at our track, obviously this is not always the case.
Old 02-21-2013, 08:24 PM   #161
Jazza's Avatar
Thanks heaps Marcus for replying, very appreciated
Old 02-22-2013, 05:28 AM   #162
Jazza's Avatar
Default Sweep Tires??
Marcus I forgot to ask. Where would be the best place to purchase
the Sweep tires from & would they ship to Australia??
Cheers Darren
Old 02-22-2013, 05:56 AM   #163
MantisWorx's Avatar
Cheers Darren
I am working on stocking them but in the meantime try
sweepracingusa.com
Not sure if they ship overseas but I am sure that they will. If they dont contact me, I have a few other contacts.
Old 02-22-2013, 09:46 AM   #164
*1speedy's Avatar
Cheers Darren
Absolute Hobbyz ships to Australia and they are a Sweep distributer
Here is a link for ya
http://www.absolutehobbyz.com/index....&filter_id=139
🏁🏁🏁 🏆🏆🏆🏆 2013 XRAY XB9 GT8 🏆🏆🏆🏆 🏁🏁🏁
2013 & 2014 R.O.A.R. REGION 1 & NY State GT8 CHAMPION!!
....................... 🏆 SPONSORS 🏆 .....................
ABSOLUTE HOBBYZ / Engines Modded by The Nitro Shop
*1speedy is offline   Reply With Quote
Old 02-22-2013, 04:23 PM   #165
Jazza's Avatar
Marcus & *1speedy thanks so much for the help guy's.
Will check out absolutehobbyz & if that doesn't work out I'll message you Marcus.
Again guys thanks for helping
Cheers Darren
Micro On Road & 1/18 Off Road Nats Thread RCMadness Micro and Mini Scales 1165 12-15-2013 03:49 PM
Team TTC GT-4 Singapore R/C Racers 7281 12-24-2010 08:45 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
