ntc3
I have a ntc3 that I want to put a 21 in it has anyone. Done this
Originally Posted by havenfun
(Post 10247528)
http://www.rcuniverse.com/forum/m_8246301/tm.htm
I'm in the process of putting a Losi 3.4 in a ntc3 http://img.photobucket.com/albums/v4...1-31202242.jpg Fits perfectly with the stock ntc3 motor mounts and losi 3.4 motor. I tried putting the 2speed clutch bell from the stock NTC# motor on my Losi motor. Clutch bell bolts on but the clutch bell isnt long enough and the bell is to big for the shoes. http://img.photobucket.com/albums/v4...1-31201732.jpg The mesh is a little off, need to find a clutch bell and maybe make some engine mounts. Or shim out the bell, but still doesnt solve the bell being too big for the shoes |
I think that may be a simple. Fix to mesh the gears. Re drill mounting. Holes for the chases. And for the clutch shoes. Try tmaxx clutch shoes maybe work
I'll look into that option. See what the lhs can come up with.
Swapped the whole NTC3 clutch/flywheel assembly onto the Losi 3.4. Now the problem is when I tighten the bolt that holds clutch bell in place, it will prevent the clutch bell from free spinning. Like its loading the bearings and not allow the clutch bell to spin freely,..I even used a dished/curved washer so it would tighten agained the inner race of the outer bearing. still no dice
Does the bolt on the end tighten up against the bearings/clutch bell? Or does it tighten up against the crankshaft and the washer holds the bell on,...? http://img.photobucket.com/albums/v4...2-02201236.jpg Losi 3.4 engine, NTC3 Flywheel/clutch assembly. I'm probably gonna rock with this gear mesh for starters. If i need to move back the engine I'll make some mounts. |
So here my suggestion do a button. Head bolt an a small washer not big. just big enough. To houldthe interior part of bearing. But definitely a button head bolt
the screw bottoms in the shaft the clutch bell should have end play you may need to add shims to the end of shaft or use a flange collar to go into the outer bearing.
Originally Posted by Mattpar
(Post 10269700)
ahh, the stock NTC3 motor had only 1 small crank screw washer. I guess I'll have to acquire more to help give me the length I need to clear the bearings.
Thanks! |
(Post 10274310)
Thanks! |
front wheel bearing spacers for my 12r5.1 worked for my os12tr as crank spacers.
I will post to my pictures to when I finish. It
Has anyone my tried. Running. A super charger on their. Street car
In process. In building. A big block for my ntc3 will be sweet
