Glow Plugs. Which One to use?
I just recently found out that I am an idiot when it comes to glow plugs. So I figured I would try to start a tread about them. I hope this one gets some attention.
So just to start things off. With high nitro are you supposed to run a cold or hot plug. I was always under the asomtion that you used colder plugs with higher nitro.
The higher the Nitro the Higher or Colder the Plug. I run 30% Byrons Fuel and I usually use the NovaMega 7 Turbo Plug. I had a hard time with the #6. I gave it to a friend that was using 20% Odenell fuel and it worked for him.
Registered User
The higher the fuel percent the colder the plug is true but I thought for longer tracks the colder the plug will result in more power at the end of the straights and just the opposite for shorter tracks. I also use 30 percent fuel and seem to have better luck with a #7 turbo plug on short tracks and a #6 on long tracks.
in my 1/10 scale I only use MC9s in my 1/8 I run Novarossi #7cold plugs in my Picco G1 Pro engine and Use #5 or plug in my R1 Race engine.
I am running both Novarossi S5 and RB 5 port. I was told to use, by a very experience boat racer to use the hottest plug possible so I always use Novarossi #5.
Always have good power from it, and just started using 40% nitro. Never short of power and haven't have any problem with the plug hot plug.
I tried once with a #6( med cold) plug, the temp drop 15% right away without any adjustment on the needles. ( using 30%)
After adjustment and the car seem to run well. But when I tried to restart, the plug broke then I decided to stick with #5.
I am sure there are advantage of using different plug, please share your expereinces guys.
Registered User
Somebody post this in the Richey Modified forum Dennis will be more than happy to clea it up!
I just got a collari xs12 5port Turbo and need to know what plug I should run with 20%.
Also, does anyone know if the OS R5 is hotter than the A8? I was was told that it was but could never get a "dependable" opinion. The OS 12TR comes with an A5 right?
The TR does come with the A5. I put it in my .12 CVR with 22% nitro and it runs cold.
