1/8th scale Motonica
looks pretty sweet..and pricey too..
I didn't even look at the price yet. I'm sure there will be more of them showing up this season anyway. The little that I have learned in my first year of this, it seems like many of the nitro on roaders don't care about price!! Makes me wonder why in the heck I didn't stick with electric!
I would expect to see some of the top drivers pick up rides from them and put them in some big A Mains this season.
VERY NICE...
motonica clutch problem
There are 4 driver used the motonica in the national race in indonesia last week end.... 2 of them having problem with the centrifugal and the clutch... after we check... the spring was diffrent ( hardness) from one to another ( all four) ... it was original from the box... anyone can help?
If the clutch was always ""engaged" you can try the following:
1. Insert a grub screw M4x4 in the central hole of each rear shoe.
2. Keep a distance 0,5-0,6 mm between front shoe and bell, to be added to a final clearance 0.1mm on the axial bearing.
If you are still not satisfied, the second solution is to cut a front shoe in three parts and fix each part BETWEEN the pins of the flywheel. In this case, lighten each portion of shoe making a hole.
I hope this helps!
We are gonna have one racing at our track this weekend for the R/C Pro Series race. I can't wait to see it.
The shocks look like Mugen's. The throttle/brake linkage is cool looking...lower c.g.!
HarKonnenD- As far as the money it takes to run gas...I agree with you, but the problem is that I still have all of my electric stuff to race and now I have added this stuff!!
show us pics at the race....
