Old 12-30-2004, 10:33 AM   #1
Default grinding gears
when i give my car throttle the gears seem to grind pretty bad. the 47t isnt moving but the others are. ive moved the motor around alot to move the gears and it still grinds. can anyone help me with this problem?
stevie605 is offline   Reply With Quote
Old 01-04-2005, 12:30 PM   #2
RCNitroDude999's Avatar
Trader Rating: 26 (100%+)
what kind of car is it?
RCNitroDude999 is offline   Reply With Quote
Old 01-04-2005, 04:59 PM   #3
rcabj's Avatar
could u give more description on your problem
BLacK cRoW RaCiNg TeaM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 02-03-2005, 07:12 AM   #4
I had the same problem on my HPI RS4 3 EVo. When I hit the throttle, I hear the engine reving but the car was inching forward. I had to change the spur gear 47 because it was worn down. The screws came loose on the engine mount and moved the engine slightly and it was enough to change contact pattern causing premature wear on the teeth. Simply enough, just replaced a 3 dollar part and tightened the engine mount screws with some thread lock and never saw the problem again.
A3 is offline   Reply With Quote
Grinding Sound when accelerating... SebTurbo Electric On-Road 18 08-13-2008 02:24 PM
1/10th Pan Car Setup - CORALLY C10X - Gears, Gears, Gears? paul73rc Oval, Larger Scales and More 4 04-06-2007 09:10 PM
Crank grinding, who to....... rcfoolz Onroad Nitro Engine Zone 11 11-03-2005 06:49 PM
Grinding diff syconate Electric Off-Road 16 09-20-2005 11:43 AM
new here, but my 4-tec is grinding...? t3guy Electric On-Road 12 05-24-2004 12:01 AM
SEO by vBSEO 3.5.0
