Tires wheels and foam inserts
Aight guy i need some help. I have a NRS4 and i need some new tires and rims. I drive my car on asphult in my delvopment. It is petty new pavement but there r still some little pebbles and gravel. So what do u guys recommend? also im looking for a new glow plug. Can u guys help me on that 2?
Thanks alot
Sean Strawsburg
Thanks alot
Sean Strawsburg
Well as far as tires. I would try Rubber. Foam is great for racing but they are a bit more expensive and you can chuck them so then you will need new tires. I would stick with Rubber for now. Plugs, well that depends on the Nitro content that you are running. What Percent is your fuel?
i think it is 20%
I run OS #8's with that.
lol im a newbie so u gonna have to explain what that is. Sorry
Let me see if I can find a good artical on plugs. I am not the best at explaining. But your plugs range from Hot to Cold. You want to run colder plugs with Higher nitro and hotter plugs with lower nitro. OS # 8 is a cold plug it is good for medium to high nitro. Hope this helps alittle.
