Old 12-25-2004, 08:22 PM   #1
Default 2 speed transmission suggestions for hpi rs4 racer 2
using 44t and 41t spur gear with 13/16 clutch bell, is that a good combo, if not was would be the best ? what can i do to keep from stripping teeth? should there be any play in spur gears and clutch bell? any suggestions would be greatly appreciated. new to r/c.
maddog55 is offline   Reply With Quote
Old 12-27-2004, 04:05 PM   #2
Rapid Roy's Avatar
Looks like you are using the stock gear ratios. They should be fine as a starting point. To the gear mesh is set properly run a peice of paper through the gears while pressing the engine to keep the gear mesh as possible. Tighten the engine mount screws then remove the paper from between the gears. This should give you the proper gear mesh. Also make sure that the engine is not twisted making the mesh looser on either of the gears.
Rapid Roy is offline   Reply With Quote
2 speed transmission for RS4 2 cougardriftr R/C Items: Wanted to Buy 0 09-02-2008 06:37 AM
Moderate basher/racer suggestions? MarkieMark231 Electric On-Road 10 06-09-2006 06:10 AM
looking for a 2 speed transmission R.C_drag_NH R/C Items: For Sale/Trade 4 01-25-2006 08:28 AM
Two Speed Transmission DAUER962 Rookie Zone 7 01-14-2004 10:03 PM
SEO by vBSEO 3.5.0
