Old 12-25-2004, 11:28 AM   #1
Default Help with new LD3
Ok well im pretty much clueless on how to get my car started I read some of the instruction manuels but they werent much help. I have put in all the batteries and added fuel and when i went to start up the engine it wouldnt work. I have like .12 pull start engine and i cant get the fuel to go through the tubes into the engine... The only think that was really happening was that the air filter was getting flooded every time i start to yank on the pull start. Can anyone help?????
Cheo is offline   Reply With Quote
Old 12-25-2004, 12:12 PM   #2
TexasRacer's Avatar
Send a message via AIM to TexasRacer
Well if the airfilter is wet that means you have fuel in your carb. The Engine might be flooded so take the glow plug out of the head and hold the car up side down to get all the fuel out and retry it again. Send me a PM if you need anymore help
Merry Christmas
TexasRacer is offline   Reply With Quote
Old 12-26-2004, 02:44 PM   #3
spenzalii's Avatar
Send a message via AIM to spenzalii
Default Ho ho ho
Hard to say what's going on there. Feel free to post more info or send another PM. There's a thread somewhere on here with tons of LD3 info, but your problem sounds more general, at least this time.
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 12-26-2004, 11:18 PM   #4
Honda_Civic_Si's Avatar
If the fuel is coming out of the air filter then that means that your fuel lines are full, you just cannot see it in the tubes....
Honda_Civic_Si is offline   Reply With Quote
SEO by vBSEO 3.5.0
