Futaba and Sanwa servos
Hi
I have a Futaba 3PK with HRS and want to use the 9451 servo and a Sanwa ERG-VX. The Sanwa servo looks like its loosing its position when i move the steering too quick.
Does anybody know if this is a known problem?
Cheers
Cheers
Originally posted by Rich Panganiban
Ziggy 12345, put your transmitter in ppm mode (standard FM) and see if it does the same thing. I believe if you run your 3PK in HRS mode w/o a digital servo that will happen. Hope that helps.
BTW, switch modes in menu 3, under "system". pg 16 in the manual.
Cheers
Originally posted by tl2111
Ziggy
ERG-VX is not a digital servo, dont use with the HRS receiver.
Ziggy
non digital servos have a slower frame rate & can literally get fried when used with an HRS reciever
Ok ill send it back to the supplier. He can send me a digital one as replacement. Whats the best digital servo for buggy steering?
Cheers
Cheers
if you wanted to stick with Futaba i've had good service from the S9451 but there's been news of a new updated S9351 which has more torque & an alloy casing
The Sanwa ERG-VX is a digital servo. It just doesnt work with Futaba HRS system. Does anybody know why?
Cheers
Cheers
Cheers
