oh o...engine problems, anyone help please?
ok, heres the go. ive got an old kyosho gx11 (?) motor, i run it about a year ago then put it away. i emptied the fuel tank but didnt do anything else (still has dirt all over chassis ...)
nehow, went to start it up today and i couldnt even pull the starter. seems the whole thing has locked tight, even the carburetta was frozen and i had to use a lever to wedge it loose again...
nebody know what i've done and how i can fix it?
thanks
thanks
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
spray nitro cleaner in it.. and also use after run oil.... coz i think the 'old' nitro has been frozen in it and become the glue that caused the piston to be 'locked' in the sleeve.
i think you better open the whole thing up and give it a GOOD CLEANING.....
also check for TEAR and WEAR....
mop
mop
thanks, how should i clean it out?
TAKE OFF CARB AND HEAD WHILE ENGINE IS STILL ONE THE CHASSIS(EASIER TO GET TIGHT SCREWS LOOSE) THEN UN SCREW THE ENGINE FROM THE CHASSIS AND TAKE APART
good ole fashioned ether. ether will eat right thru the gum. same as walmart brand carburator cleaner.
