Skidding Problem
Skidding Problem
Hi guys, just want to ask about how to setup Vone SII to avoid skidding. can you give some specific instructions. is it the camber? springs? wish you can help me. tnx a lot.
also have a read on the V one S forum about other V one S cars and their setups
alot of good info and pics
check it out : http://www.rctech.net/forum/showthre...s&pagenumber=1
thanks
thanks
hey tnx again
ok il check it out... tnx.
I am not familiar with your car and it's handeling characteristics, but I would suggest getting the XXX-Main setup guide. It explains the pros and cons to various adjustments. It also gives different scenarios and how to correct a situation with possible setups to cure the problem you may be having.
where can i get that xxx-main is it a magz?tnx
thanks men
tnx but probably not right now, im a little tight in my budget just spent too much from some modifications, if its ok can you share urs...tnx
Too much info and too many situations covered to really share and be accurate. I can only guess what your car is doing. Your best bet is to save the money up for it.
One way to really get a hold on the situation is to get yourself a setup board like a HUDY system and a tweak station for the suspension. Those are the tools of a serious racer or even just someone who want their car to perform at it's best. Again, those tools cost money but are well worth the investment.
