Old 12-05-2004, 10:02 AM   #1
Default Ground Clearance issue
Hi all, im from the UK, and im considering getting an on road, 1/10 or 1/8 scale, to race round the local parking lots and, hopefully, on to the closet club I can find.
My biggest issue I have with these awsome onroad cars is "Ground clearance".
It seems that the videos I watch from the USA seem to have the smoothest tarmac going.
Could all you onroad guys out there please list the ground clearance of your cars so that I might be able to get an idea as to what I can expect from these kits
neo010969 is offline   Reply With Quote
Old 12-05-2004, 11:02 AM   #2
Roger's Avatar
For my nitro 1/10 scale sedan: 4-5mm on front and 5-6mm on the rear. Depending on how new and smooth the surface is, i'll go lower sometimes.
For my nitro 1/8th scale on-road: 5-7mm up front and 7-8 mm on the rear. Again, if the surface is new and smooth, i'll drop her down lower if needed.
Just keep in mind regarless of what right height your trying to accomplish for on-road nitro applications, you'll bottom out every so often. I haven't met a racer that didn't have any scratches on the bottom side of his chassis if racing on asphalt or concrete. Goodluck.
Roger is offline   Reply With Quote
Old 12-05-2004, 12:13 PM   #3
Thanks Roger, im on the case. Now I just need to choose my on road "ride"
Old 12-06-2004, 02:13 AM   #4
bulletdays's Avatar
Thumbs up thats it
i think that is a good grnd clearance, i use 5mm front, 6mm back
bulletdays is offline   Reply With Quote
Old 12-06-2004, 03:22 AM   #5
Jap TC3's Avatar
At my local track.. a bit bumpy, I running 6mm front & rear ride height...
Jap TC3 is offline   Reply With Quote
Old 12-06-2004, 11:11 PM   #6
smracer31's Avatar
Send a message via AIM to smracer31
i think you just need to adjust it for where your going to run, the track i run at which is a prmanent track and very smooth we run about 2-3 mm to get as low center of gravity as possible and reduce traction roll.
smracer31 is offline   Reply With Quote
Old 12-08-2004, 11:58 PM   #7
wayne's Avatar
aight... I have a ntc3 rtr plus, and I have adjusted it to run on like a loose surface sand but still hard and not too flat, (I used rally type tyres btw) and I found that a ride height of 6.5mm all around and the lowest droop possible or number zero on the front and a droop of one on the back worked quite well, I know what I am proposing sounds pretty stupid, but I did it to prove that it could be done and to race a friend with a buggy, he claimed that tarmac wasn't fair and I suppose he's right, but now the challenge is on him to get his buggy to be competitive on tarmac
BTW : we were 2 all in the races, and he didnt want to go for a decider
ALSO : I believe I could have got the car to perform better on the surface, but it got to the point where I just decided "that seems good enough"
wayne is offline   Reply With Quote
1/8 on road ground clearance vic88my Nitro On-Road 14 10-31-2007 02:18 AM
tc5 never hit the ground lonslo R/C Items: For Sale/Trade 10 09-07-2007 05:32 PM
1/10 Kit - from the ground up CogLioStro Rookie Zone 3 05-16-2007 08:18 AM
ground-round A+++ polesitter61 Buyer/Seller dispute and Feedback discussion forum 0 06-01-2006 09:02 AM
rs4 3 ss chassis on the ground never lift Nitro On-Road 13 01-16-2006 11:34 AM
SEO by vBSEO 3.5.0
