Old 11-29-2012, 11:56 AM   #121
RC-Netshop.dk's Avatar
Default Capricorn C02 Worlds Edition
Hi everybody,
Just wanted to say the C02 Worlds Edition is ready, Cap will probeably announce it one of these days officially.
Only 100pcs is produced.
Upgrades are:
All suspension parts in hard plastic version
New belts
New spring pipe support
Weight under tank
F1 sway bar
New 2speed shaft
http://rc-netshop.dk/en/
Capricorn, REDS, CRC, Orcan, JP GIMAR, Ielasi Tuned, Tesla, JQ, Sanwa
RC-Netshop.dk is offline   Reply With Quote
Old 11-29-2012, 12:11 PM   #122
Originally Posted by RC-Netshop.dk View Post
Hi everybody,
Upgrades are:
New belts
Weight under tank
F1 sway bar
New 2speed shaft
Here´s a picture...
Old 11-30-2012, 04:09 AM   #123
Default Lab C01 / 02 a bit confusing?
Hey guys why don't we merge the thread as i believe that who needs support for the 02 there isn't as much info and help as there is in the 01 thread, after all differences are quite minimal.
speed6 is offline   Reply With Quote
Old 11-30-2012, 04:13 AM   #124
Default Kevlar diffs
Hey people, just installed the new Kevlar Front/Rear Diffs
The material since its slippery doesn't hook that well to the screws so be careful when tightening.
The rest looks great but whats strange is that i filled the front with 120,000 and the rear with 60,000 and the REAR feels harder than the front how is it possible?
Maybe it needs some work?
Old 11-30-2012, 05:46 AM   #125
blis's Avatar
Air bubbles/pocket?
Just for a test we used a shock vac pump when making our diffs. We placed a large ball of cleaning gum in the base to consume a large part of the volume of air and placed the open diff on top and began evacuating the air. The large amount of bubbles expanded and rose to the top, it was 120,000 oil and the amount of air bubbles were unexpected. Whether it made a difference or not I cant really say. One thing is for certain though, a diff that's rotating at high speed will apply large centrifugal forces to the oil and will create a hollow center, where it's really needed.
We've been advised to filled the diff to beyond capacity and while it's a messy job, the diffs last a long time and are consistent. Our's finally stripped bevel gears after many months of use, well beyond the time I thought they would last.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 11-30-2012, 10:57 AM   #126
Originally Posted by blis View Post
Air bubbles/pocket?
I did use a vac pump and let it rest for an hour to be sure and re vacuum. Oil is filled up to the top for sure!
Old 11-30-2012, 01:24 PM   #127
Chickentrader's Avatar
Something is binding. Also; gears are too tight if diff action is not smooth and feels notchy.
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media – The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 12-10-2012, 11:44 PM   #128
Bundy_Bear's Avatar
Here´s a picture...
Is it only available as a kit?
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 12-11-2012, 10:22 AM   #129
DS Motorsport's Avatar
When you build a new diff you should always refill it after one run. After the diff has been used the oil gets in all the corners of the housing. This will lower the oil level to the minium amount. How thicker the oil is, the more important this becomes.
Also the new kevlar diffs hold more oil compared to the standard diffs so they should feel slightly softer. Because they hold more oil the diff will be more consistent during long runs.
All the parts are available, but not in a upgrade kit.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 12-11-2012, 12:35 PM   #130
Default Capricorn LAB-C02 WC Edition
Finally on my own..
The WC Upgrade parts were already in the kit which came factory sealed.Lab C-02-image.jpg
Italboy is offline   Reply With Quote
Old 12-11-2012, 01:18 PM   #131
Yes, only as a complete kit. Capricorn only had 100 cars produced, so it's limited.
Old 12-11-2012, 03:52 PM   #132
nikoskar's Avatar
How do you know that?Just asking
www.rc-world.gr
nikoskar is offline   Reply With Quote
Old 12-12-2012, 01:18 AM   #133
No, problem in asking. For the simple reason that it was what Capricorn informed us of as their distributor...
Old 12-12-2012, 02:24 AM   #134
Bundy_Bear's Avatar
Thanks Nikko
MissMooRC Racing
Old 12-13-2012, 12:18 AM   #135
Thanks Nikko
No, problem :-)... Always glad to help...
Niko
Bartolina pambihira Singapore R/C Racers 21951 03-22-2017 01:58 AM
Capricorn LAB-C01 Korey Harbke Nitro On-Road 2059 07-16-2013 09:12 AM
How many RC's do you own???? Telengard Electric On-Road 127 02-22-2011 12:52 PM
High Performance Nitro MassiveMods Australian Racing 1318 03-12-2009 03:52 PM
