Old 11-07-2012, 04:48 AM   #106
DS Motorsport's Avatar
Originally Posted by cap View Post
Jacques Liebenberg takes South African championship for 2012 ,after winning the last nats
Originally Posted by speed6 View Post
http://www.facebook.com/pages/Main-H...type=1&theater
1st Championship Race with a 1st Place
Thanks everyone for the support!
Congratulations to the both of you, good job!.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 11-07-2012, 04:57 AM   #107
Hey people is it just our track or does 1/10 car handling change so much??
Well last week i did some testing since i received the Cap Progressive springs
I normally find that the car has better steering / handling running full red springs against black full springs.
Ran the Progressive and it felt that the car had better sterring but wasn't that stable.
Ran Front Progressive with REar REDS and it got a bit better but no so different
Ran Front Progressive with Rear BLACKS and it was all over the place and steering became to much aggresive.
Is there some sort of popular combinations for the Progressives and how come they felt they had more steering more than the REDS?
By the way i am running the car lenth with a 1MM shorter as tried the 2MM but was to aggresive but i quite liked the 1MM even though its not easy to drive as it is with the long wheels base.
When there isn't any traction every car will slide. Also when the traction is low driving becomes more important compared to setup.
With the progressive springs the initial reaction will improve because of the softer spring rate in the beginning.
They do need a good amount of traction because they are quite hard after the initial roll.
We may need red progressive springs, I will make the suggestion to Capricorn.
With the Capricorn cars 99% of the time I run the same color springs in the front and rear and the car feels really balanced.
I always run the car in the long wheelbase configuration, tried the short wheelbase several times but never liked it. Always felt like the car over rotated in mid corner.
The quickest fix to get rid of oversteer is increasing the rear toe. If the traction is low you can easily go to 3,5 degrees of rear toe in.
Don't know which tires you are running, but with the Capricorn tires I also make the rims softer on a low traction track using the Capricorn rim reamer tool. This makes the car a lot easier to drive and it increased corner speed.
P1-RC.com
Old 11-07-2012, 05:57 AM   #108
Hey DS thanks for the above MSG and for the next support msg
So the Black progressive are compared as being part of the black family shocks?
I don't even like the short wheelbase but that was the only way to get more steering which i did loose more rear grip than got steering so i might go back to long wheel base as car is to nervous.
Re: Toe in i am running 2.5 with Contact 40 in the rear and 37 in the front.
Tried the Cap but with the Contact was faster
So to try and not loose off power steering and also try and get more grip at the rear on power whats the quick-fix? Just run more rear Toe?
speed6 is offline   Reply With Quote
Old 11-07-2012, 06:37 AM   #109
Yes, the black progressive have a mediant hardness which is comparable to the regular blacks.
Yes, go back to long wheelbase and try getting more steering through another way.
I would try adding some front droop, so a lower downstop value.
This will give you more weight transfer towards the rear during acceleration but doesn't influence the car a lot during braking. It might cause a little understeer in chicanes/fast direction changes, but this shouldn't be an issue.
P1-RC.com
Old 11-07-2012, 06:52 AM   #110
dj apolaro's Avatar
DS is giving you great advise here. Definitely keep the car long. Maybe also try less caster in the front. This will help the car go in better and have less steering on power. Make it drastic and move the arms all the way forward. Just to see if it really helps. If it is too much than bring them back little by little.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 11-07-2012, 07:36 AM   #111
75% of our turns are chicanes
Will give it a try as it does make sense a lot!
Old 11-07-2012, 07:38 AM   #112
DJ Apolaro
Hey DJ with my K car I ran the least caster possible which helped a lot but the Capricorn its the oppsite as it doesn't seem to like it at the track.
Old 11-07-2012, 08:00 AM   #113
dj apolaro's Avatar
OK, Just figured it might be worth a try. I run black front and red rears most of the time and my car seems very balanced.
I do use my rear camber links shorter than most racers and this gives a quick response for the chicanes and helps with the turn in. However, it can make the car unstable at times depending on your set-up.
DJ Apolaro
Old 11-07-2012, 08:03 AM   #114
Default front diff
which way is more easy to change the front diff?
brosla7 is offline   Reply With Quote
Old 11-07-2012, 10:59 AM   #115
DJ Apolaro
I also run the shortest link in the rear as I find it to flow better in turns. Will try black upfront and red rears. If I manage to remove the power slide issue I might try again the front progressive with reds rear as I really liked it!
Old 11-07-2012, 12:00 PM   #116
Try 35 in front, I find this combination works for me better than 37/40 and the wear is more even.
majk is offline   Reply With Quote
Old 11-11-2012, 07:00 AM   #117
RC-Netshop.dk's Avatar
Default "Johnsen Design" Carbon Radiobox holder
Hi,
Just finished installing my "Johnsen Design" bracket for holding a radiobox....
Fitīs the C01/C02 and C801... Looks cool and works!
Still got a few left if any is interested send me an email...
http://rc-netshop.dk/en/
Capricorn, REDS, CRC, Orcan, JP GIMAR, Ielasi Tuned, Tesla, JQ, Sanwa
RC-Netshop.dk is offline   Reply With Quote
Old 11-13-2012, 02:51 PM   #118
Another WIN
http://www.facebook.com/#!/photo.php...type=1&theater
Thanks guys
Old 11-13-2012, 03:02 PM   #119
Default Getting the right setup
Sooooo....... after a very hectic and long weekend trying to sort out the rear issue stepping out when ever i hit the gas especially on right turns, changed setup etc... etc... we found out that the front belt lost allmost all the teeth so the car was behaving rear wheel drive on throttle than its gets to 4wd once it get going bastard.
Unfortunatly race day was on Sunday so had no time to experiment. Drove the car with stock setup but with RED springs and 3 rear toe 37 fronts and 42 rear and car was understeering heavily in the chicanes. For the race i installed a thicker rear sway bar and reduced a bit the rear toe-in to help the on throttle steering response.
It did help but i still suffered in the offpower entry steering into chicanes.
What i am going to try and kindly acknowledge is softer front shock oil maybe go to 40 and lighten the front and rear diff oil. I was suggested to go for 80,000 front and 40,000 rear but this was an xray guy so don't really know how it will react on a cap diff.
Kindly suggest to get more off power steering
Also thanks to the belt issue i realized how much powerful the engine is turning to the right than to the left. I know that its a gforce issue and thought of tryin the following http://www.capricornrc.com/capricorn...id_product=323 on my Novarossi 12PT, what do you guys think?
Thanks once again
Old 11-14-2012, 05:46 AM   #120
Chickentrader's Avatar
Thanks once again
Is very rare for someone to need more steering with this car in my experience, unless something else is causing it. You should most definitely try a new steering servo, even if you think that the one that you have is O.K. I've seen that problem before, and it is very hard to isolate.
Kindest regards,
Lars
P.s. Jiles is looking very strong at the Worlds at the moment. Let's all hope that Capricorn can nail it! Here's a picture of the Australian Team of Peter Jovanovic, Chance Karlsson and Ashley Seaward; left to right (no misguided drivers here; we're all Capricorn). On behalf of the Austrlian team; i would like to thank Capricorn Australia for donating the Australian team T-shirts.
Support your local RC stores - they support our sport!
Social media – The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Bartolina pambihira Singapore R/C Racers 21951 Yesterday 01:58 AM
Capricorn LAB-C01 Korey Harbke Nitro On-Road 2059 07-16-2013 09:12 AM
How many RC's do you own???? Telengard Electric On-Road 127 02-22-2011 12:52 PM
High Performance Nitro MassiveMods Australian Racing 1318 03-12-2009 03:52 PM
