Old 06-23-2012, 05:36 PM   #91
Trader Rating: 12 (93%+)
Go DJ!! Get some pics of his car
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 06-24-2012, 09:44 AM   #92
Default DJ takes TQ at Byrons
DJ holding his TQ lab
spdmkr is offline   Reply With Quote
Old 10-14-2012, 04:23 AM   #93
blis's Avatar
For Capricorn RC drivers and those who don't mind a biased race report.
http://www.capricornrc.com.au/austra...c-titles-2012/
Special thanks to Andrew Shapland - "True Blue Mobile Mechanic" for the images.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 10-23-2012, 11:55 AM   #94
dj apolaro's Avatar
Hey guys,
This weekend we had our Nationals in the USA. I am still getting setting back into my work so give me a couple of days to post my set-up. My car was really fast all event. Just had bad luck in the Finals. Capricorn took the Sedan TQ very convincingly and had the fastest car of the event by far. Ended up 4th in the final after all the issues.
Will post a set-up later this week
Thanks,
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 10-23-2012, 06:39 PM   #95
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Default Cap UPPERDECK??
Originally Posted by dj apolaro View Post
Hey guys,
Thanks,
DJ Apolaro
1st off let me say, good run at the nats........Quick question....How are you running your upperdeck on your C02? stock, custom cut, or like jilles completely cut away from the steering post?? can u post pics of your car when you get a chance.....no rush!!
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 10-25-2012, 07:16 AM   #96
dj apolaro's Avatar
Here is a picture of the front upper deck. Also I am putting here my set up from the Nationals. Don't mind the dirty car!! LOL
My car was fast and fits my driving style. Car carries a lot of corner speed with this set up.
If there are any questions just ask and I will do my best to answer them.
Hope it helps out,
DJ Apolaro
Old 10-25-2012, 03:20 PM   #97
GREGORY!'s Avatar
Hope it helps out,
DJ Apolaro
DJ?why you need so much rear camber in that car?that has so little suspension 'geometry' flex?do you have oversteer with less?
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 10-25-2012, 03:25 PM   #98
DS Motorsport's Avatar
3 to 4.5 degrees of rear camber is pretty normal for a nitro tc.
DJ also uses very little camber gain in the rear (no shims on the upright) so the camber doesn't change a lot during suspension travel.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 10-27-2012, 03:53 PM   #99
Chickentrader's Avatar
My experience (for what it's worth) is that the faster you go the more camber you need. It is quite normal for our car to start with 3 and 3.5 deg. left - right rear, and when and then find that the tires start to cone out later when the track gets faster. We usually end up with 3.5 - 4 or 4 - 4.5 deg., and rear tires usually coning in marginally or wearing flat. Same goes for front where we start with 1 - 1.5 deg. left right, but usually end up with 1/2 deg. more camber when the grip comes up.
That is with long links and running at moderate angles, so the camber gain is also moderate. The camber would obviously have to be less with setups that generate more camber gain.
I never bothered to find out, but I wonder what rear camber the guys that were using that DSL rear suspension a couple of years ago used on their cars?
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 10-28-2012, 10:52 AM   #100
dj apolaro's Avatar
I run more camber for 2 reasons. Since I use mess camber gain I need more regular camber. Also since I like my car to slide in the rear for corner speed, this helps me keep the car predictable for my driving style. I have changed my style of driving over the last couple of years to fit more the aggressive style and in doing this I needed more camber.
DJ Apolaro
Old 10-29-2012, 05:01 PM   #101
Hope it helps out,
DJ Apolaro
Hey DJ,
could you kindly confirm
Rear bottom roll center block marked 2, what does that mean exactly?
Front Shock piston with one hole what size?
I also noticed that you run a screw in the left hand side on the upper tray next to the 25 gear, how come more stabilty at the cost of steering?
speed6 is offline   Reply With Quote
Old 10-29-2012, 06:16 PM   #102
dj apolaro's Avatar
Originally Posted by speed6 View Post
Hey DJ,
I also noticed that you run a screw in the left hand side on the upper tray next to the 25 gear, how come more stability at the cost of steering?
There are 5 positions in the rear lower pins. The lowest is #1 and the highest would be #5. The middle would be #3. I was the position between the lowest and middle position.
There is only one size piston that I know of. They come in 1, 2, 3, 4, 5 or 6 holes. I use the 1 hole pistons in the front.
I have only tried not using the screw once and the car felt like it was not as consistent with the steering in the middle of the turn. So from that point on I always used the screw like it is stock from the kit. I have not felt like I need more steering for a while. I seem to have the steering I need at all the track I have been running lately.
DJ
Old 10-31-2012, 12:11 PM   #103
cap
Jacques Liebenberg takes South African championship for 2012 ,after winning the last nats
cap is offline   Reply With Quote
Old 11-06-2012, 03:30 PM   #104
Default Great win for Capricorn Malta
http://www.facebook.com/pages/Main-H...type=1&theater
1st Championship Race with a 1st Place
Thanks everyone for the support!
Old 11-06-2012, 03:42 PM   #105
Default Dirty Track = Lab rear on power tries to drift!
Hey people is it just our track or does 1/10 car handling change so much??
Well last week i did some testing since i received the Cap Progressive springs
I normally find that the car has better steering / handling running full red springs against black full springs.
Ran the Progressive and it felt that the car had better sterring but wasn't that stable.
Ran Front Progressive with REar REDS and it got a bit better but no so different
Ran Front Progressive with Rear BLACKS and it was all over the place and steering became to much aggresive.
Is there some sort of popular combinations for the Progressives and how come they felt they had more steering more than the REDS?
By the way i am running the car lenth with a 1MM shorter as tried the 2MM but was to aggresive but i quite liked the 1MM even though its not easy to drive as it is with the long wheels base.
Bartolina pambihira Singapore R/C Racers 21951 03-22-2017 01:58 AM
Capricorn LAB-C01 Korey Harbke Nitro On-Road 2059 07-16-2013 09:12 AM
How many RC's do you own???? Telengard Electric On-Road 127 02-22-2011 12:52 PM
High Performance Nitro MassiveMods Australian Racing 1318 03-12-2009 03:52 PM
