Old 04-06-2012, 04:37 PM   #61
Originally Posted by TeamCarnage View Post
Not to barge in... but LMK when you guys are gonna be at LH. Last year seemed like the turnouts were amazingly low. I raced the MWS, but passed on the Byrons race. Regretted it big time. I know the el. guys are gonna have good turnouts. Menace, last time I seen you was about 4 years ago, pitting outside the south fence! Happy Easter! Nick A
I won't be ready for gas shake down until early may.
PhatPat is offline   Reply With Quote
Old 04-08-2012, 06:47 AM   #62
British Menace's Avatar
Well hello Nick. Yes, its been a while. I think I may have caught the "bug" again.... lol
Maybe this time I will graduate and marshal at the North fence with the Big boys ... hehe
Looking fore ward to getting my car!!
How have you been?
BM
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 04-08-2012, 02:26 PM   #63
MrHistory's Avatar
assembled the front diff no problem. when assembling the rear diff, the hole drilled in one diff cup shaft seems to be in a slightly wrong spot. The pin has to be forced through the shaft, and causes the assembled half to be very tight, not spinning freely as the others do. Can i drill this out more? Does it need replacing?
Also, there is one bad diff bearing so it looks like i wont be finishing anytime soon. I do not wish to buy these parts. The kit is $700 and I do not intend to spend $740 to get it together.
Irwin RC 1/8th Pan Car Specialists - www.irwinrc.com
SPM Competition, WRC Racing, MIP, Novarossi
MrHistory is offline   Reply With Quote
Old 04-09-2012, 01:46 PM   #64
Hopefully you will have better luck when you start racing the car....
One question I do have ....
did your kit come with the Nit ride coated titanium shock shafts?
BM
Old 04-09-2012, 11:02 PM   #65
nikoskar's Avatar
Lab-C02 comes with plastic diff gears?If yes how often do you change them?
www.rc-world.gr
nikoskar is offline   Reply With Quote
Old 04-11-2012, 08:05 PM   #66
MrHistory's Avatar
Probably the best thing to do is skim through the Lab C01 thread from beginning to end. I did this recently when I got the C02 kit. This should answer most of your questions.
Yes, the kit comes with composite gears, which are great according to those who have had the car for a season or more, and where said to be like new after a half season of racing by a driver writing in the C01 thread.
My C02 kit came with the following parts:
1. Titanium shock shafts
2. composite gears
3. lightweight axles
4. Aluminum servo saver
5. Kevlar pulleys
6. Low-friction belts
7. Blade style front plastic upper bumper support
8. Plastic battery tray
9. Aluminum one-piece motor mount
10. Standard C02 radio tray (not ffs flex radio tray)
11. Standard blade-type anti-roll bar (not new design)
Old 04-12-2012, 09:14 AM   #67
I heard Capricorn are comming out with Titanium CVD's for t&e C-02 .......... is that right?
Old 04-28-2012, 09:24 AM   #68
This thread is strangley quiet ....
Since I got the car .... lol
Anyway,
The 'light' Capricorn flywheel nut CAP-408L
Does anyone have one of these? Are they actally lighter then the stock item?
BM
Old 04-28-2012, 04:05 PM   #69
KMW
KMW's Avatar
Anyway,
BM
2.6g compared to 1g for the light version.
KMW is offline   Reply With Quote
Old 06-11-2012, 03:13 AM   #70
Hi all
I'm lacking a bit of entry and early mid
Corner steering this is the set up I'm
Useing
Down stop F 1. R 4
Ride height F 6.5. R 7.5
Tyres F 60. 37s R 62. 40s
Springs. F&R black
Dampening F&R 3 hole 60w
Shock pos F&R down
Sway bars F 1mm R 2 mm
Diff oils F 200. R 70
Roll centre Front Inside middle
Roll centre Rear upper arm Inside middle
Roll centre Rear lower arm 1 up from bottom.
Upper arm 1.5 mm at hub
Ackerman 11 steering 23deg each side
Caster 2mm each side Of arm
Camber FL 1 1/2 FR 1 1/4
Camber RL 3 1/2 RR 3
Track width F 197 1/2 R 199
Top deck cut out no brace in
Also is it better to run the front upper arm
In or out which one will give more steer
Thanx in advance
monaro is offline   Reply With Quote
Old 06-11-2012, 03:13 AM   #71
Hi all
Useing
Down stop F 1. R 4
Springs. F&R black
Shock pos F&R down
Thanx in advance
Old 06-11-2012, 04:25 AM   #72
DS Motorsport's Avatar
I would first try some more caster, go to 1mm behind the arm.
Secondly you could try the 0,9mm front anti roll bar.
All other settings seem to be pretty good, balanced.
A shorter front upper arm will give more steering at corner entry, the car also reacts quicker. I had some problems with achieving the right camber settings though, I had to shorten the upper pivot ball by 2mm to get the desired camber settings with the shortest upper arm.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 06-11-2012, 05:36 AM   #73
thanks DS ill give it a try this weekend and report back
cheers
Old 06-11-2012, 06:14 AM   #74
dj apolaro's Avatar
Originally Posted by monaro View Post
Hi all
Useing
Down stop F 1. R 4
Springs. F&R black
Shock pos F&R down
Thanx in advance
I would also think about trying
- 3 rear droop
- 150km front diff
- 35 shore front tires
With these changes you should get much better turn in and middle. You could even go to 198 on the front track width to keep the car smoother.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 06-11-2012, 10:05 AM   #75
Hello friends!
I had a pre race weekend trying to find the best set up for My CO2 ( the only in Greece....hihihi) and start using Your set up DS.
The only problem is that the track was very slipery and I will need softer springs than stock. ( I think I must ordere them from Cap )
I tryied to set up the front solid axle and check the letest low grip that Our Friend DS pablished but I am having a problem.
How am I going to use the plastic ship with the axle since it doesn't stay in place? Should I use a glue and glue it to the pinion?
If somebody can help please do...
As for shofter springs I used the Blue Xray ( same length ) but I think I will need something harder..Maybe violet...
s.i.jerefos is offline   Reply With Quote
Bartolina pambihira Singapore R/C Racers 21951 Today 01:58 AM
Capricorn LAB-C01 Korey Harbke Nitro On-Road 2059 07-16-2013 09:12 AM
How many RC's do you own???? Telengard Electric On-Road 127 02-22-2011 12:52 PM
High Performance Nitro MassiveMods Australian Racing 1318 03-12-2009 03:52 PM
