Old 05-10-2014, 08:53 AM   #496
DS Motorsport's Avatar
Originally Posted by Brian Bosley View Post
Is it a euro thing that everyone seems to run the wide low bumper and carbon upper and we seem to run foam?
In Europe almost all the tracks have grass runoff area's, so no boards to crash into.
The wide low bumper gives a bit more steering at high speeds, and imo it looks better. The lightweight foam bumper looks good to though.
Mounting the front bodyposts directly to to upper carbon plate gives the car a slightly sharper response, because front end downforce is transferred directly to the bulkheads.
Originally Posted by John.C View Post
My flywheel broke and I'll need another. I'm wondering if the Xray NT1 flywheel is a suitable replacement. See details.
Don't know whether this would work, but why change to an inferior part?.
Has anyone tried using an Xray NT1 flywheel? Will I need to get the Xray shoes?
Originally Posted by speed6 View Post
Bumb
I would recommend the Mugen tool, with this one you can screw the pins out.
With the Hudy you have to use a hammer which is less precise.
Pins can be bought from Capricorn, Team Titan or Hudy, all having about the same quality.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 05-11-2014, 06:32 AM   #497
John.C's Avatar
Trader Rating: 36 (100%+)
It really came down to timing of the incident. The part broke on Friday and there was no chance of me receiving the Capricorn part in time from our online reseller. I had hoped that this Xray part might be available at a LHS in my area but I ended up borrowing my buddy's Cap flywheel. I just hope Capricorn USA sells/stocks a black (or non red) flywheel.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 05-11-2014, 11:04 AM   #498
el salvador's Avatar
What exactly is wrong with your Capricorn Flywheel ? If One of the flyweight pins was broken, these can be replaced. I had this happen a couple years ago and, at the time, I cut down to length the shaft from a 2 mm drill bit to fit. The roll pins used, I believe are 12 X 2 mm and are available from Capricorn and probably other MFG's as well.
I've since then obtained the correct replacement pins from Capricorn but am too lazy to replace the modified pin I made, it still remains in the flywheel. HTH
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
Old 05-11-2014, 12:08 PM   #499
John.C's Avatar
Old 05-11-2014, 12:46 PM   #500
Wow! looks like whatever "Road Hazard" that didn't digest well, made it past the "Corinthian Leather" Mud Flaps. My condolences and "Never Mind".
Old 05-11-2014, 08:33 PM   #501
gsxr0311's Avatar
Trader Rating: 18 (100%+)
Ouch!
Special Thanks to: RC Target, Ko Propo USA, O'Donnell glow plugs, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, and TE03. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. CRC 235mm Pro-10, Top Rebel 12
gsxr0311 is offline   Reply With Quote
Old 05-11-2014, 11:35 PM   #502
H4gI's Avatar
You got more steering without the foam, because of less weight on the front.
With the controlled 37/40 tyres at the races you need all the steering you can get...
cheers
Team NFC
LRP
CAP
Nitro-mechanic-bitch of E.D. and R.V.
H4gI is offline   Reply With Quote
Old 05-12-2014, 02:16 PM   #503
Michael_T's Avatar
Trader Rating: 47 (100%+)
Send a message via MSN to Michael_T
cheers
The wide bumper is about 20 grams heavier than the small bumper + foam.
Michael_T is offline   Reply With Quote
Old 05-13-2014, 09:08 AM   #504
Trader Rating: 17 (100%+)
who is the US distributor? Looking to get some parts..
T.O.P Racing USA
"This T-bird will put a spell on you"
Mr.A Morris is offline   Reply With Quote
Old 05-13-2014, 09:13 AM   #505
dj apolaro's Avatar
The US guys are CapAmerica RC.
www.capamericarc.com
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 05-15-2014, 03:30 AM   #506
H4gI's Avatar
I dont knwo which wide bumper you use... but with ours its less heavier + cut out the wide one... something about a bit of common sense ......
We tested both and I think eric isn't the slowest driver....
Team NFC
LRP
CAP
Old 05-15-2014, 04:51 AM   #507
Michael_T's Avatar
Xray bottom stock bumper - 9.0g
Xray wide bumper - 23.7g
Xray foam - 4.0g
Sorry, 10.7g difference.
Old 05-15-2014, 04:25 PM   #508
Just weighed the different options:
Standard bumper setup
Lightweight foam with carbon upper plate and cut lower support
Xray wide bumper with cutouts and my own bodypost plate.
This is lighter compared to using the stock upper plate and bodyposts
So the standard bumper setup and the xray wide bumper are pretty close in terms of weight. The upper plate I use removes a couple of grams which makes the Xray wide bumper setup a bit lighter compared to the stock setup
The lightweight foam bumper setup is clearly the lightest option.
P1-RC.com
Old 05-15-2014, 04:32 PM   #509
Trader Rating: 12 (93%+)
DS why the cutouts in the lower bumper?
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 05-17-2014, 08:24 AM   #510
From what I've tested it smoothens out the initial steering response, it makes the steering more linear.
P1-RC.com
Bartolina pambihira Singapore R/C Racers 21950 01-14-2017 01:29 AM
Capricorn LAB-C01 Korey Harbke Nitro On-Road 2059 07-16-2013 10:12 AM
How many RC's do you own???? Telengard Electric On-Road 127 02-22-2011 01:52 PM
High Performance Nitro MassiveMods Australian Racing 1318 03-12-2009 04:52 PM
SEO by vBSEO 3.5.0
