Old 03-17-2014, 02:08 PM   #406
Trader Rating: 20 (100%+)
Selling my Lab-C02 WC. Interesteds check here FS. Capricorn Lab-C02 WC Edition plus extras
Schumasher CAT K1 AERO/HobbyWing V3.1 ESC/HobbyWing V10 6.5T Motor/IP Batteries
WWW.SPEEDLINEHOBBY.COM "A HOBBY STORE FOR RC RACERS"
IVAN RM is offline   Reply With Quote
Old 03-17-2014, 04:56 PM   #407
Default Protoform SRS-N on Black Edition
Dear all,
Which body post holes are you using as for height of the SRS and do you shave the foam bumper to make it fit? Or you move the body more upfront?
speed6 is offline   Reply With Quote
Old 03-17-2014, 05:02 PM   #408
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
I would mount it even with the front wheels. And shave the foam bumper.
Inf1nity CM Beat1 Racing
Serpent-Dan is online now   Reply With Quote
Old 03-17-2014, 05:10 PM   #409
DS Motorsport's Avatar
Originally Posted by speed6 View Post
Dear all,
I mount mine 4mm forward. To me this gives a nicely balanced car with the wing all the way back (10mm).
Regarding the height, I cut it following the trimline and then make sure it doesn't hit the ground when on track.
I think the SRS is the only body which actually has a usable trimline.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 03-18-2014, 05:59 PM   #410
How do you exactly measure the 4mm forward, distance between front foam bumper and body? Since neither the rear or front wheels align well at center.
Old 03-30-2014, 10:40 AM   #411
Default Black edition setup help
Hey guys, so have been running the Black edition and have it on rails, fastest lap time and i can feel the car to be a bit superior than the competition, its practically stock items, what i have changed is a step harder front shocks and 8 hole piston in the rear shock with 1300 allround
Also used the new clutch reversed system and found it better than the normal one. Smoother take off!
So you might be saying whats my problem, basically during practice and qualification the car is .50 per lap slower (avg lap 19.2sec) and very hard to drive (unstable). My biggest concern is that in chicanes the car understeers and on some others tight turns it oversteers heavily that i loose control its also very twitchy. How am i going to sort this out.
They prep the track by sugar and water and from how i set the brake i have noticed that track is very slippery early in the morning.
Suggestions plz
Old 03-31-2014, 07:37 AM   #412
RC-Netshop.dk's Avatar
Default C02 BE + M3 WCS
Take a look, first practice this year with C02 Black Edition and REDS M3 WCS engine
https://www.facebook.com/#!/rc.netshop.dk
All the best,
Niko
http://rc-netshop.dk/en/
Capricorn, REDS, CRC, Orcan, JP GIMAR, Ielasi Tuned, Tesla, JQ, Sanwa
RC-Netshop.dk is offline   Reply With Quote
Old 04-01-2014, 07:24 AM   #413
John.C's Avatar
Trader Rating: 36 (100%+)
All the best,
Niko
Looks great Niko. I can't wait for our outdoor season to start here in the next couple of weeks. It's been a long winter, but, Spring is finally here!
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 04-01-2014, 04:48 PM   #414
All the best,
Niko
Those reds motors are so fast.
Ran with a friend that only runs reds last week. Fast, fast, fast
JOE SI is offline   Reply With Quote
Old 04-02-2014, 07:08 AM   #415
John.C's Avatar
What springs (spring rate) come with the big bore shocks in the Black Edition kit? There's no making and/or number to determine what they are. It does appear that all 4 are the same.
Also, my 2 speed gear assembly has a good amount of side by side play (approx 1-1.5mm) when it's installed in the rear transmission. I built/measured per the instructions. Did I do something wrong? Is this normal or should I shim this out?
Thanks in advance guys.
Old 04-02-2014, 10:59 AM   #416
Hahahha, thanks John :-).... YES, summer is finally here!!!!
Old 04-02-2014, 11:03 AM   #417
Hi John,
I will check for you, can't remember what springs it is in the BE kit :-)...
I also got a bit of play, but shims it up a bit. I make so I just have a little play and all is running freely
Old 04-02-2014, 11:19 AM   #418
John.C's Avatar
Hi John,
YGM
Old 04-02-2014, 11:51 AM   #419
3.4 springs. They should have a gold engraving on the top of the springs
Old 04-02-2014, 12:13 PM   #420
John.C's Avatar
Thanks Dan. I double check when I get home, but, I recall it being silver. I could be mistaken though.
Found this to be helpful.
Bartolina pambihira Singapore R/C Racers 21951 03-22-2017 01:58 AM
Capricorn LAB-C01 Korey Harbke Nitro On-Road 2059 07-16-2013 09:12 AM
How many RC's do you own???? Telengard Electric On-Road 127 02-22-2011 12:52 PM
High Performance Nitro MassiveMods Australian Racing 1318 03-12-2009 03:52 PM
