Old 03-01-2014, 07:45 AM   #391
DS Motorsport's Avatar
Originally Posted by monaro View Post
Hi can someone tell me if the brass chassis weights effect the handling of the car. or are they just to bring the car up to weight. Some other brands have a sliding weight they claim by moving it back gives more steering. does our weights have the same effect. I never use mine because the car is already over weight Thanks in advance
Adding weight towards the rear of the car will improve rotation, moving it forward makes it more stable.
For example the heavy motormounts and the U-shaped brass weights increase steering.
The heavy battery plate makes the car a bit more stable and it also stiffens the chassis.
The heavy front bumper makes the car more stable.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 03-01-2014, 07:46 AM   #392
Time to start preparing for 2014:
I will post some pictures of all the updated parts, the car has some nice new features.
P1-RC.com
Old 03-01-2014, 03:43 PM   #393
Trader Rating: 12 (93%+)
DS is that a red or black edition ? What are the new changes?
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 03-01-2014, 04:03 PM   #394
DS do you think a new Capricorn will be released any time soon
Old 03-03-2014, 06:23 PM   #395
Thanks ds I'll put them in and see how it goes may be worth carry the extra weight I have been lacking rotation in the middle of the turn this may fix it cheers
monaro is offline   Reply With Quote
Old 03-04-2014, 02:48 PM   #396
It's a red one, the Blacks are completely sold out.
Updates
-New chassis, less wide and adjustable servosaver position
-New radiotray, different design and adjustable servosaver position
-Updated servosaver design, decreases the angle the trackrod needs to make between the servosaver and the servoarm
-Double reverse clutch set
-Updated lower bulkheads to allow more steering lock and to enable servosaver position adjustment
-Knurled brakeplates to enhance brakepad adhesion
-V2 Big Bore shocks
As far as I know this will the car for the 2014 season.
P1-RC.com
Old 03-04-2014, 09:52 PM   #397
gsxr0311's Avatar
Trader Rating: 18 (100%+)
Smile
OOOoooo, nice.
Special Thanks to: RC Target, Ko Propo USA, O'Donnell glow plugs, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, and TE03. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. CRC 235mm Pro-10, Top Rebel 12
gsxr0311 is offline   Reply With Quote
Old 03-08-2014, 11:03 AM   #398
Pictures of the updated chassis and radiotray:
This allows the servosaver to be moved forward or backwards, giving more ackermann options.
P1-RC.com
Old 03-08-2014, 11:29 AM   #399
Comparison between the three optional battery trays:
Carbon fibre
Brass
And the new ultra heavy Beryllium tray
The goal is to make my 2014 car light enough to use all the heavy parts and still make the min. weight limit.
P1-RC.com
Old 03-08-2014, 12:29 PM   #400
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
My Black Edition has that tray and chassis
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 03-09-2014, 11:48 AM   #401
Ok, mine came with the C02 optional chassis and the Full flex radiotray.
P1-RC.com
Old 03-09-2014, 11:51 AM   #402
The new double reverse clutch:
This clutch works in two ways, the regular way and the new, reversed, style.
Flyweights with chamfer on both sides:
And everything mounted:
P1-RC.com
Old 03-09-2014, 02:06 PM   #403
John.C's Avatar
Trader Rating: 36 (100%+)
DS - Is this a new car (i.e. C03) or is it a C02 with updated parts? I have a black edition and based on the pictures you posted I believe I have the chassis but not the updated radio tray. It'll be nice if I can upgrade this and the other parts mentioned if it'll work on my black edition C02.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 03-10-2014, 06:54 PM   #404
It's the updated C02.
All of the updated parts will fit the black edition. Only problem might be the new front lower bulkheads. These have more room for the servosaver so it can move forward. I don't think these are available in black anodizing. But you can modify them with a dremel yourself , I did this to my black edition bulkheads.
P1-RC.com
Old 03-11-2014, 11:35 AM   #405
RC-Netshop.dk's Avatar
Default XRD Engines
XRD Engines... Looks goood :-)....
https://rc-netshop.dk/15_xrd-engines
http://rc-netshop.dk/en/
Capricorn, REDS, CRC, Orcan, JP GIMAR, Ielasi Tuned, Tesla, JQ, Sanwa
RC-Netshop.dk is offline   Reply With Quote
Bartolina pambihira Singapore R/C Racers 21950 01-14-2017 01:29 AM
Capricorn LAB-C01 Korey Harbke Nitro On-Road 2059 07-16-2013 10:12 AM
How many RC's do you own???? Telengard Electric On-Road 127 02-22-2011 01:52 PM
High Performance Nitro MassiveMods Australian Racing 1318 03-12-2009 04:52 PM
SEO by vBSEO 3.5.0
