Old 01-07-2014, 06:46 AM   #376
Default Big Bore membrane problem + preload
Dear all,
i have a problem with the big bore membrane getting deformed (like reversed bubble) and wont go back to its original state. Any one with the same problem.. I am running 4mm preload with a 1mm hole drilled on the upper cap for a smoother ride in our bumby track.
speed6 is offline   Reply With Quote
Old 01-07-2014, 07:05 AM   #377
dj apolaro's Avatar
Originally Posted by speed6 View Post
Dear all,
It may be possible that you are hitting the membrane when the shock is fully compressed. It should not really ever, but maybe that is what is going on. Make sure that on the fronts, you have the plastic ball ends tightened completely, so the shaft does not go all the way up and the piston sits more in the middle of the body. Depending on the rear and the way you use it, you may have to monitor this as well.
Also when building the shocks it is important to make sure the membrane is centered very well. I try to make sure when I tighten the cap I spin the plastic part so that the membrane stays centered.
Let me know how things go and good luck. I am not sure but I think there may also be an updated membrane that fits the big bore shock a little better in the center of the body.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 01-07-2014, 11:14 AM   #378
DJ Apolaro
That's what I did I tightened up all the way and now I tried kyosho v1 rrr bladder which I had running around. They sealed very nice and I also check the seating like you said. Car was using all the travel as the body plastic mount on the rear shock tower had tire marks (strange but true) I also went for a heavier spring all round. Will be doing some testing this weekend, car was dialed before the bladder issue. Thanks DJ
Old 01-12-2014, 10:22 PM   #379
Can someone post a setup for fort myers using big bore shocks as a starting point?
younghovaa is offline   Reply With Quote
Old 01-14-2014, 08:57 AM   #380
dj apolaro's Avatar
I would run your normal set up and make the shocks with 1 hole front and 2 hole rear. use 50 wt oil in the front and 55 rear. 4.6 front spring and 3.9 or 3.8 rear spring. Start with them laying down. If you run the rear extensions then go 1 up.
I will post what I am going to use for a starting point set up later today.
See ya there in about a month,
DJ Apolaro
Old 01-14-2014, 01:12 PM   #381
DJ Apolaro
ok thanks DJ.. I Have a new kit B.E so never ran before.
Old 01-14-2014, 01:51 PM   #382
dj apolaro's Avatar
Here is what I am going to start with. I am assuming the traction will be high. If not my settings may change. We will just have to see.
Thanks,
DJ Apolaro
Old 01-16-2014, 03:53 PM   #383
GREGORY!'s Avatar
can someone post the black edition manual?
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 01-17-2014, 07:35 PM   #384
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
If your looking for the big-bore shocks build. Download the electric Lab TE02 manual from the web site.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 01-21-2014, 03:18 PM   #385
DS Motorsport's Avatar
There isn't s specific black edition manual.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 01-27-2014, 11:00 AM   #386
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Hi guys,
New to on road nitro. Thinking of picking up the lab c02 black edition. I found a seller on ebay selling it for 669USD shipped. Is that a good deal on the car? Also is there a new one coming out soon? Not familiar with product releases in onroad since mostly an offroad racer. Xray is coming out with the 2014 but I am staying away from xray since parts are too expensive (and I break xrays as well ). Who will be selling parts in the USA? Acorn racing/speedworld (my LHS) won't carry them anymore so I might have to settle on the xray but I do love the LAB cars.
-Alok
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-27-2014, 11:25 AM   #387
dj apolaro's Avatar
The new importer for the USA is www.capamericarc.com
They have everything you may need and a live website. If there is something you are looking for, you can always email them for help. I am working with them on doing videos and they are very involved in the race community.
you can also check them out on www.facebook.com/capricornamerica
Good luck and I am sure you will love the car. It is second to none!!
DJ Apolaro
Old 02-06-2014, 03:32 PM   #388
Default Black Edition linkage plastic parts
Hi there
Is it possible that the white plastic parts for the linkages are missing?
There are just the white parts for the shocks included.
Italboy is offline   Reply With Quote
Old 02-08-2014, 07:35 AM   #389
Originally Posted by Italboy View Post
Hi there
The black edition should have come with the white plastics.
If they aren't in your kit contact your reseller or Capricorn directly.
You should receive the parts with no questions asked.
P1-RC.com
Old 02-16-2014, 05:27 PM   #390
Default Chassis weights
Hi can someone tell me if the brass chassis weights effect the handling of the car. or are they just to bring the car up to weight. Some other brands have a sliding weight they claim by moving it back gives more steering. does our weights have the same effect. I never use mine because the car is already over weight Thanks in advance
monaro is offline   Reply With Quote
Bartolina pambihira Singapore R/C Racers 21951 03-22-2017 01:58 AM
Capricorn LAB-C01 Korey Harbke Nitro On-Road 2059 07-16-2013 09:12 AM
How many RC's do you own???? Telengard Electric On-Road 127 02-22-2011 12:52 PM
High Performance Nitro MassiveMods Australian Racing 1318 03-12-2009 03:52 PM
