Old 05-13-2013, 08:39 AM   #256
British Menace's Avatar
Thanks. It will be interesting to hear what you think DJ ....
Did you happen to measure what the new bore and stroke is of the new shocks? .... just interested.
BM
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 05-13-2013, 09:40 AM   #257
dj apolaro's Avatar
Sorry, did not bother.
DJ Apolaro
BM
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 05-22-2013, 09:23 AM   #258
YBSLOW's Avatar
Default Gears
Anybody have the part #'s for the metal diif gear set for the C02?
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source
POWER MASTER Fuel,
Protoform Bodies, Avid Bearings
YBSLOW is offline   Reply With Quote
Old 05-22-2013, 09:24 AM   #259
YBSLOW's Avatar
Originally Posted by dj apolaro View Post
Okay,
So I built the shock this weekend just trying to be prepared for next week. In terms of travel they have plenty so there should be no worries with a track that is bumpy versus flat. Performance we will have to see. I would think that on bumpy track they will be as good if not better based on how my shock felt. The hole in the piston is larger than the standard one, which I like. Instead of 50-55 wt I built them with 60 for the larger hole piston. I also used 1 hole front and 2 rear, as that is what I always run as a standard (better response left to right). I only got 2 spring rates to start with. They seem soft, I think they compare to the blue as the soft and slightly softer than the blacks as the harder ones. I think I will start with the harder strings all around for my first test. The old springs will not fit.
I am very picky with how my shocks feel, so these did take me a little more time to build, especially since I am not used to the shock body's. Be patient on your first time with the bladder and the body. After I got them build they feel pretty good. I do feel like the shock action without the spring is smoother on these shocks. I will try to do some good testing at the KO race, but with running 2 classes and preparing for the Nationals, sometimes the time just fly's by.
One thing for sure, they are a lot lower than before.........
DJ.
How did testing of the new shocks go?
YBSLOW Racing
POWER MASTER Fuel,
Old 05-22-2013, 09:52 AM   #260
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
I don't think cap has a metal set, (I could b wrong). But my crew all use Xray gears
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "D815 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / ko propo RSX / FUTABA 4PX / Novarossi
1evo RRR Driver is offline   Reply With Quote
Old 05-22-2013, 10:12 AM   #261
YBSLOW's Avatar
Thanks, thats what I was afraid of. Kind of like putting a honda part on my Ducati......J/k. don't need to hear from the haters.
YBSLOW Racing
POWER MASTER Fuel,
Old 05-22-2013, 11:12 AM   #262
prtmotorsport's Avatar
i had my first test with my lab co2 wc, and all i have to say is the car is amazing.very fast and very stable ,forgiving .... i am very pleased finally.
i have a question why do you change from plastic to metal gears for reliability?
how often should you change the oil if you use the plastic?
Capricon Lab CO2-picco edo mod
prtmotorsport is offline   Reply With Quote
Old 05-22-2013, 11:17 AM   #263
nikoskar's Avatar
There is no need to change to metal gears. Fill your diffs correct and you aren't having any problems.
There aren't plastics. Are carbon made. Open your case and check the oils.
www.rc-world.gr
nikoskar is offline   Reply With Quote
Old 05-22-2013, 11:26 AM   #264
From experience, plastic is great if u don't run on 2x4 wood tracks, or even if u do you just can't contact the boards much!! If ur over seas with grass runoffs plastic will prob last for a couple seasons!! Not sure how often to change oil, if its not leaking it stays a long time, but I would say after every 2races or so!
Old 05-22-2013, 12:06 PM   #265
YBSLOW's Avatar
Default gears
I have only been racing 8th scale recently and decided to put a sedan together. I have seen a lot of blown plastic diff gears on brand x cars and have heard they usually run metal gears in longer main events? Just something I thought I would put in my bag.
YBSLOW Racing
POWER MASTER Fuel,
Old 05-22-2013, 12:21 PM   #266
dj apolaro's Avatar
For longer mains or to play it safe you can use a rear Xray diff with their metal gears. That is probably your only real option.
As for the new shocks. I was only able to run 1 test and I think since the pistons have larger holes I need to go even stiffer than I did. The ones I built where not what I was looking for and I went back to what I normally run. Since I was racing 2 classes and helping pit, I just did not have the time to rebuild more shocks and keep testing. I think I will try them again with 70 wt oil next time. The track has a lot of direction changes and you need a car that changes direction very quick.
DJ Apolaro
Old 05-22-2013, 12:59 PM   #267
i know nikos they are carbon made thank uou for the tip. And i am from greece
so i should change the oil especially on the back every two races or every race and posibly for a long final?
Old 05-22-2013, 01:10 PM   #268
DJ Apolaro
Congrats DJ for the winning event!!!
Hey Guys..I have a very slippery conditions...a lot of dust in suspension...so the chasis is very stiff and the car just drift...
What do you recommend for this situation... the track is very smooth...not bumpy, its very fast layout but it has a technical section...like "W" shape in which I have to slow down the car a lot to make the turn...
Thanks!
TomasRC is offline   Reply With Quote
Old 05-22-2013, 03:07 PM   #269
nikoskar's Avatar
You can check them after each race. If isn't any leak and the oil is clear you don't need to change it.
Mine i change them every 2 races but before each final i check them.
PS: If you follow manufacturer build instructions you won't have any problems.
www.rc-world.gr
Old 05-23-2013, 12:05 AM   #270
thank you nikos!
Bartolina pambihira Singapore R/C Racers 21951 03-22-2017 01:58 AM
Capricorn LAB-C01 Korey Harbke Nitro On-Road 2059 07-16-2013 09:12 AM
How many RC's do you own???? Telengard Electric On-Road 127 02-22-2011 12:52 PM
High Performance Nitro MassiveMods Australian Racing 1318 03-12-2009 03:52 PM
