Old 04-25-2013, 09:35 PM   #211
MrHistory's Avatar
Okay got it. thank you
Irwin RC 1/8th Pan Car Specialists - www.irwinrc.com
SPM Competition, WRC Racing, MIP, Novarossi
MrHistory is offline   Reply With Quote
Old 04-25-2013, 11:46 PM   #212
blis's Avatar
Originally Posted by DS Motorsport View Post
It depends on which gears you're using. It's only possible to align the gears perfectly straight when the total amount of teeth are the same for both gearsets.
So for example a 52/15 and 47/20 gearing adds up to a total of 67 teeth on both gearsets. This allows you to align the gears perfectly straight. When both gearsets don't have the same amount of total teeth it's impossible to align the gears straight. When this is the case I would recommend setting the first gear mesh the best you can. The second gear mesh is less important, since it wears a lot less.
From my experience, our on road nitro gears have fixed diameter gears. Adding more or less teeth changes only the pitch of a tooth.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 04-26-2013, 03:12 AM   #213
djiewie's Avatar
Blis , best to check if this is true also for the CAP with your digital caliper gauge.
Xray have this and they use a fixed motormount. The CAP however have slots in the chassis to slide the motor mount (with the motor) to the gears.
I would like to know also. Easily done with diameter check to the several spurs.
djiewie is offline   Reply With Quote
Old 04-28-2013, 08:35 AM   #214
Default new chassis
Anyone tried it yet???
speed6 is offline   Reply With Quote
Old 04-29-2013, 04:41 PM   #215
MrHistory's Avatar
I have a new lab c02. $400 shipped.
Partially assembled
diffs, clutch, shocks and other parts still in bags.
Old 04-29-2013, 05:00 PM   #216
el salvador's Avatar
Partially assembled
Sent you a PM.
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
Old 04-29-2013, 07:12 PM   #217
British Menace's Avatar
Hey.
Just to CAP off what was discussed earlier about spur diameters and mesh etc. Pardon the pun .....
DS is right. All the spurs have the same pitch so fewer teeth means a smaller diameter. Not to panic too much though. The difference is small. Eg: The 53 tooth spur measures 44.8mm while the 52 tooth spur measures 44.65mm in diameter.
BM
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 04-30-2013, 11:33 AM   #218
jackcarter3's Avatar
I found what I was looking for.....
jackcarter3 is offline   Reply With Quote
Old 04-30-2013, 01:23 PM   #219
djiewie's Avatar
Originally Posted by British Menace View Post
Hey.
BM
Thanks, that clarifies it
Old 05-01-2013, 08:55 AM   #220
RC-Netshop.dk's Avatar
Default Radio Box Brackets "Johnson Design"
Hi guys,
We got the radio box brackets back on stock, price are 12EURO or app. 16USD...
http://rc-netshop.dk/en/
Capricorn, REDS, CRC, Orcan, JP GIMAR, Ielasi Tuned, Tesla, JQ, Sanwa
RC-Netshop.dk is offline   Reply With Quote
Old 05-01-2013, 12:21 PM   #221
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Originally Posted by RC-Netshop.dk View Post
Hi guys,
Does that work for the c02 also? N is that the mugen box?
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 05-01-2013, 07:32 PM   #222
Les
Les's Avatar
Default Glue
Hi, Wondering what is the best glue to use on brake pads ?
Cheers
Serpent S411 4.0 13.5T D4
Kyosho V-ONE S3, RB Rota-Start
Sanwa MT4S
Les is offline   Reply With Quote
Old 05-01-2013, 08:12 PM   #223
MrHistory's Avatar
c.a. glue and epoxy both work. i use c.a. rough sand the metal side, apply even coat of c.a. to entire surface, apply break pad. after positioning pad, i put a block of wood on top and clamp it for a few minutes, or just press down on the wood. this makes a nice flat fit. be sure not to glue the pad to the wood. metal can be stuck but is easily removes with knife.
after glue is dry, i trim the edges of the pad to clean up glueand then scuff the pad side by rubbing face down on a piece of 400 sand paper in a circular motion for a few seconds. this preps the pad for use and removes any glue.
Old 05-01-2013, 08:26 PM   #224
Les
Les's Avatar
Thanks Jason for the detailed procedure, very much appreciated.
Sanwa MT4S
Old 05-02-2013, 02:37 AM   #225
Yep, works for the C02, C01 and C801 :-)... We have made it so it fits Mugen MTX5 radio box.
Br,
Niko
Bartolina pambihira Singapore R/C Racers 21951 03-22-2017 01:58 AM
Capricorn LAB-C01 Korey Harbke Nitro On-Road 2059 07-16-2013 09:12 AM
How many RC's do you own???? Telengard Electric On-Road 127 02-22-2011 12:52 PM
High Performance Nitro MassiveMods Australian Racing 1318 03-12-2009 03:52 PM
