Old 04-24-2013, 12:30 AM   #196
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Default Shock extenders!
Made from silver carbon
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "D815 PILOT" /FUSION X3LCFM / M2c / ko propo RSX / M11x / Novarossi
1evo RRR Driver is offline   Reply With Quote
Old 04-24-2013, 12:31 AM   #197
Default One more
One more
Old 04-24-2013, 10:16 AM   #198
Originally Posted by desotoracing View Post
It's probably faster and cheaper to order it from us in the USA.
I see your instock on the c01/02 stuff, thankyou will b placing a order with you real soon
Old 04-24-2013, 12:27 PM   #199
prtmotorsport's Avatar
Originally Posted by 1evo RRR Driver View Post
One more
very nice...
what does it do compared to the normal position??
Capricon Lab CO2-picco edo mod
prtmotorsport is offline   Reply With Quote
Old 04-24-2013, 02:23 PM   #200
Originally Posted by prtmotorsport View Post
very nice...
I would imagine its for more sidebite! I only made them cause Dj apolaro seems to use them on his setups, n rightnow his La setup is on my car ni love it, minus the 1hole piston......
Old 04-24-2013, 04:12 PM   #201
MrHistory's Avatar
So i installed my motor with clutch and two speed all box stock and was trying to set the gear mesh.
The outer gear mesh is very tight and the inner gear mesh has a lot of slop. Looking at the motor mount screws under the chassis the motor is correctly squared up, meaning the motor is 90 degree perpendicular to two speed. In order to have a good mesh for both 1st & 2nd gear I would have to mount the motor at a slight angle. Whats up?
Irwin RC 1/8th Pan Car Specialists - www.irwinrc.com
SPM Competition, WRC Racing, MIP, Novarossi
MrHistory is offline   Reply With Quote
Old 04-24-2013, 06:15 PM   #202
A slight angle is ok/normal for us. We use 14/19 pinions and 53/48.
desotoracing is offline   Reply With Quote
Old 04-24-2013, 06:42 PM   #203
MrHistory's Avatar
Old 04-24-2013, 10:35 PM   #204
Trader Rating: 32 (100%+)
See the link below, which gives you better idea how others did to theirs.
http://slowbunnyrc.blogspot.com/2012...ification.html
hobbs is offline   Reply With Quote
Old 04-25-2013, 12:37 AM   #205
djiewie's Avatar
very nice...
- the shock is more angled so softer damping and spring,
- the travel on the shock rod is more with the same bumps because it is further on the arm,
- the shocks are a fraction higher mounted so higher rc,
- more weight unsprung
djiewie is offline   Reply With Quote
Old 04-25-2013, 12:43 AM   #206
Is there a limit where the shocks should be angled down???
Old 04-25-2013, 01:17 AM   #207
djiewie's Avatar
Its a setup thing. Getting the most out of damping. To me the angle should be
90 deg to the travel. But angling the shocks more will get you progressive travel on the shock more or less wich can be benificial to the specific situation. The car will have initial soft damping wich by compressing will alter the angle on upward arm travel and will get more travel into the shock at a higher speed wich generates more (harder) damping. Hope it all makes sence to you usin one oil rate to get soft and hard damping when you want it when the weight is transferred to where you need it on the wheel.
The 8 scale have the most angled shocks and electric tc the least. Because it works, why i don`t know besides what i said/wrote.
Old 04-25-2013, 09:15 AM   #208
DS Motorsport's Avatar
It depends on which gears you're using. It's only possible to align the gears perfectly straight when the total amount of teeth are the same for both gearsets.
So for example a 52/15 and 47/20 gearing adds up to a total of 67 teeth on both gearsets. This allows you to align the gears perfectly straight. When both gearsets don't have the same amount of total teeth it's impossible to align the gears straight. When this is the case I would recommend setting the first gear mesh the best you can. The second gear mesh is less important, since it wears a lot less.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 04-25-2013, 07:33 PM   #209
MrHistory's Avatar
Thanks for explaining that DS!
Just to be clear, first gear meaning the inside gear nearest engine?
Old 04-25-2013, 08:46 PM   #210
Joe Kimble's Avatar
Send a message via Skype™ to Joe Kimble
No that's the second gear Think of it as like on a bike, same deal...
Serpent America
Sweep USA
RCShox
Joe Kimble is offline   Reply With Quote
Bartolina pambihira Singapore R/C Racers 21951 03-22-2017 01:58 AM
Capricorn LAB-C01 Korey Harbke Nitro On-Road 2059 07-16-2013 09:12 AM
How many RC's do you own???? Telengard Electric On-Road 127 02-22-2011 12:52 PM
High Performance Nitro MassiveMods Australian Racing 1318 03-12-2009 03:52 PM
