Serpent centax clutch end play help!! >
Old 10-21-2011, 12:46 PM
Default Serpent centax clutch end play help!!
Hi im trying to fit my centax clutch to a 12 engineon an followed the manual exactly but cant get no end play once iv put it all together... I have to loosen the end screw to get any end play and iv tried using more shims both before and after the clutchbell.....any help?
evolva2011 is offline
Old 10-21-2011, 01:08 PM
lil-bump's Avatar
Trader Rating: 89 (100%+)
You need to remove all of the shims from behind the flywheel. You may have to get a different flywheel cone which mounts the flywheel closer to the engine. Remember the closer the flywheel is to the front engine bearing the more room you have left once you stack the entire clutch together.
Pass you soon...
lil-bump is offline
Old 10-21-2011, 04:03 PM
Thanks iv just seen serpent do there own collets so ill try one of theirs!
Old 10-21-2011, 04:11 PM
lil-bump's Avatar
Keep at it Good luck
Pass you soon...
lil-bump is offline
Old 10-21-2011, 08:01 PM
bobbyblaze's Avatar
Pass you soon...
+1 on the flywheel...i ran into that problem where i kept dusting the clutch shoe and realize the flywheel wasn't back far enough
bobbyblaze is offline
Old 10-22-2011, 01:49 AM
Thybaut's Avatar
I grind the cone until the flywheel is as close as possible to the crankcase. This reduces the stress on the bearings, as well as give you more space to shim the clutch the right way.
An other option is to use shims on the end of the crankshaft (between crankshaft and thrustbearing spacer).
Thybaut is offline
Old 10-22-2011, 02:28 AM
asw7576's Avatar
How did you grind the cone and make sure it is flat bottom ?
asw7576 is offline
Old 10-22-2011, 02:47 AM
Thybaut's Avatar
I use a Dremel first and 600 wet sandpaper to sand it flat. It doesn't matter if it isn't completely flat, but the flatter the better.
Thybaut is offline
Old 10-23-2011, 08:45 PM
Geezatec's Avatar
Remove shims @ engine brg and collet. Assemble the centex as normal. Use depth gauge to determine how much endplay you have. Total play i.e. 1.50mm. Shims came with centex kit came with 3x.50 shims. add 2 shim. and reassemble clutch assembly. You should have endplay or .50mm which is in tolerarance of specs.
Geezatec is offline
Old 11-01-2011, 05:51 PM
Wink
Double check your black clutch shoes. Make sure u didn't put it wrong the flat surface is facing up.
PeterL is offline
