Is it true that harder front foam compound than rear will give better steering ???
Hey all, these weekend i was having a very interesting topic with this fellow and subject was how can you get the most possible steering.
On my Lab C801 i am running a one step softer shore upfront to get more steering, but my fronts are wearing to much comapared to the rears. I don't want to go a step up shore as i don't wont to loose the steering i have BUT this person was explaing to me that actually steering will get better since the side wall of a harder tire will be harder and get more grip than the other tyres i had as he was explaing that softer compound suffer from a very soft sidewall and will flex whilst steering hard.
Whats your idea about this?
That MIGHT be true if you are running very large tires. Even then I doubt it though.
I read the same thing in XXX Main. It says use a harder front tire to you get more lateral grip. But everyone at the track runs a softer tire up front. I've been running softer tires up front since that what everyone has recommended but this has always confused me.
Also need to take into consideration all the dampening and suspension settings. All these will effect the tire shore and grip as well.
If only one manufacturer could make an 8scale front tire like the electric foam Cyan tires of old: 45shore edge with 35shore inside....
They have a 40 shore compound on the inside and a small ring of 32 shore on the outside.
It's called Bi Mescola..
The harder the tyre the larger slip angle have to apply, otherwise it's understeer much esp 1/8 has turning ability at real end.
I dont think so.
More understeering.
More understeering.
Too soft and too much diameter and you will chunk the tyres and then it's bad news for steering.
Depending the surface......
You can go to soft with a tire causing less grip......
Also on dusty surfaces a softer tire can pick up the dust loosing grip while a harder tire does not pickup the dust.
