Old 12-09-2004, 05:40 PM   #31
ttso's Avatar
Originally posted by macnkitty2002
the guy i got my ntc3 from went to a specialty plastics shop and got his gear boxes molded in kevlar. they look sweet and hold up great.
macnkitty2002, can u take some photos of that amazing kevlar gearbox?
ttso is offline   Reply With Quote
Old 12-09-2004, 08:55 PM   #32
If you mesh all the gears on the ntc3, you shouldn't be blowing ANY gears. I used to blow my diff and pinion gear until I learned how to adjust the mesh properly. Now I haven't had anything break on the car from just using it.
kwong2001 is offline   Reply With Quote
Old 12-09-2004, 08:59 PM   #33
OnRoad-Racer's Avatar
Send a message via AIM to OnRoad-Racer
I have racd my NTC3 for an entire season and only replaced the diff once but not for damage, mainly for the "murphy's law" factor. I run an NS12S3 in my NTC3 and never had a problem with it. Not to mention that I am running an aggressive shift (6 tooth drop ... 21/27 Pinion and 54/48 spur).
The diffs lifespan will depend on how you rebuild them, which you should do after every weekend of competative racing or once a month if just bashing around. If the diff is too tight, you will strip your gears. You can't lock it down or stick a solid axle in and expect long life.
The one issue I wish AE would take care of is the front suspension. Granted, someone invented "The Fix" but AE should address this issue as well. Clip a board too hard and your shocktower will twist slightly and rip out the screw from the diff housing.
AE went the right route by addressing the rear suspension and upgrading it. They just need to step up and do something about the front and make it more bullet proof. Till then, "The Fix" will be your best friend.
OnRoad-Racer is offline   Reply With Quote
Old 12-12-2004, 10:29 AM   #34
macnkitty2002's Avatar
ttso, i have no camera now. i was planning on getting digital but when my tc3 caught fire during a drag race, i used up my money to fix it up. man, a new hardcore titanium chassis can hurt the wallet, not to mention a new m8 radio. oh, and dont worry, the diff cases were unharmed
macnkitty2002 is offline   Reply With Quote
4tec 3.3 or NTC4 ? Yankeesfan239 Nitro On-Road 8 05-31-2008 06:49 AM
Ntc4??????????????????? factory racer Nitro On-Road 21 07-24-2006 07:25 AM
fast cash for Ntc3 ntc4 Resale_Warehous R/C Items: For Sale/Trade 5 03-04-2006 02:30 PM
NTC4 Anytime Soon? or new R40? scoobydo Nitro On-Road 32 09-08-2005 02:22 PM
NTC4 !!!!!!!!!!!!! 12cellnitro Nitro On-Road 4 10-21-2004 02:51 PM
SEO by vBSEO 3.5.0
