Old 09-20-2011, 10:19 AM   #1
Trader Rating: 45 (98%+)
Default 1/8 GT On Road Help
Before anything is said...I'm probably just going to be parking lot bashing most of the time. Budget is about $600...I have my own radio gear so AM stuff will be taken out ASAP.
Before I started studying on DM-1 Spec, Kyosho IGT2, Ultra GTP, GTP2e, 1/7 DM-1 Pro...it became even more mind boggling lol. Damn Kyosho bodies are about $100 on top if I want to mount it on the DM-1 Spec which I think are not going to line up...does anyone know the wheelbase of the 1/7 DM-1 Pro?
Each car has its pros and cons I know...leaning on the IGT2 is the 2 speed tranny that big of an issue? I've been seeing some $64 metal 2 speed upgrade on ebay for quite some time.
Anyone used this?
alexchen86 is offline   Reply With Quote
Old 09-20-2011, 02:12 PM   #2
C-Trickle's Avatar
The GT2 is an awesome machine! For cheaper body options, you can always throw a Dragon Racing GT1 chassis on it, or for all out strength, do a Kyosho 777 Chassis conversion. Then you can run the non licensed bodies *PF8 etc*.
However, the Kyosho bodies are very strong, and reinforcing them with mesh and shoe goo will go a long ways.
You want to go with the Kyosho Shoe Type Transmission once the stock one finnally quits. Kyosho IGW008. It's a direct drop in on the GT2.
The DM-1 spec and GT1 share the same wheelbase, the GT2 and DM Pro share the same wheelbase. I would say GT2 or DM-1 Spec. I personally think the DM Pro is just too heavy! Plus the GT is a little easier to setup.
Hope that helps.
C-Trickle is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro On-Road 9642 10-20-2016 09:09 AM
GT8 Class--buggy-based on road electric! snrscion Electric On-Road 3416 05-05-2016 12:10 PM
~1/8 Scale On-Road GT Picture Thread~ Justpassedu Electric On-Road 163 12-30-2015 10:28 AM
SEO by vBSEO 3.5.0
