IGT2 clutch bell/werks clutch/LRP engine - Too much free play?
I'm pretty this is too much front to back free play, but is this normal with only one shim? Seems to be a lot.
Engine is LRP.30 Spec2, clutch is Werks 34mm "Medium" Pro 4 Shoe Racing Clutch System. Clutch bell is factory Inferno GT2. Currently only using the one shim my original factory clutch had.
Can that amount even be shimmed? looks like it would take a good number of them.
Looks like you're gonna have to shim it so that the shoes make full and proper contact with the bell!
When you set the engine on the chassis what position does the gears line up at? When I set up my LRP .28 I had to shim the collar, before the flywheel, so that the gears would line up. I hope that makes sense.
