Cutting Large Windshield Hole w/ Hole Saw
Hi All, I have read a lot of posts on the topic and would like some advice on drilling the large holes in the windshield and back window of my nice new sedan body.
A lot of posts say a hole saw works great for this. I have a set of hole saws for woodworking, is that they type they are talking about? The have a drill bit in the middle that acts as a pilot and then different size hole drill pieces?
The reason I ask is because the teeth on these things are pretty course since they are for wood. Won't they rip the plastic up instead of cutting smoothly? Do you use a fast drill speed or slow? Thanks for any tips, all the other holes I did are perfect and I don't want to mess up this custom painted body.
I should also mention that I have another custom painted truggy body that I need to cut the engine hole for and that is a big hole. The hole saw method looks like the easiest way to get it perfect. I looked at the hole cutting tools with the exacto type blade but I am not confident using one of those.
I have used hole saws before, it works well but you do need to be careful.
A better option is an Olfa circle cutter.
http://www.olfa.com/CircleCuttersDetail.aspx?C=51&Id=65
The reason the circle cutter won't work on the truggy is the hole is almost against the cab so I can't get the cutter in a complete circle because the non=cutting end will hit.
You didn't mention truggy, this is the onroad thread
I just used a cordless drill and went slow.
R/C Tech Elite Member
I use a Greenlee chassis punch. Makes round, square, or oval holes from 1/2 to 1 1/2 in diameter. Just drill a hole in the center of where you want the hole to be, insert the bolt with cutting head, then screw on the bottom cutter & tighten. Does a great job of making clean cuts & doesn't warp or burn the Lexan!!!
Did you use a slow drill speed? Did you back up the other side with wood? Or just drill slow and don't push hard on the drill?
Thanks guys for all the advise and tips. Looks like a lot of different ways to accomplish the same thing, some of them I never knew!
I would normally just jump in and try it but I have never spent this much on two bodies so I am cautious about screwing them up. But I have plenty of info now to get it done.
Thanks again!
Thanks again!
Here Is The Finished Product...
OK well I tried the hole saw and I didn't like it. Unfortunately it grabbed and spun the body a little, putting some scratches on top from the wood I was backing it up with.
Fortunately I used a smaller hole saw than was ultimately needed and it had gone part way through.
So instead I used a shot glass and traced a circle on the front and back, then used a very sharp exacto to score it. After that I cut pie shaped pieces into the score from the middle and snapped the pieces off.
Then the dremel drum sander and cutting blade for the flat parts to clean it up. It's not perfect but not too bad - next time I will be better.
I will post a couple pix so you can critique my work, thanks again for the support guys.
If you're going to use the pilot-bit style hole saws, that are
made for cutting wood and sheet metal, on a lexan body. Get a reversible
drill and use the saw in reverse rotation to drill the lexan. It will cut
the lexan alot smoother without digging the teeth of the saw
into the body and possibly ripping the body up.
