Old 08-21-2011, 03:10 PM   #16
Jake C6R's Avatar
Originally Posted by rageworks View Post
If you're going to use the pilot-bit style hole saws, that are
made for cutting wood and sheet metal, on a lexan body. Get a reversible
drill and use the saw in reverse rotation to drill the lexan. It will cut
the lexan alot smoother without digging the teeth of the saw
into the body and possibly ripping the body up.
I thought about that after I ripped it up going forward. But I made such a mess of it I resorted to scoring it by hand.
Jake C6R is offline   Reply With Quote
Old 08-21-2011, 09:39 PM   #17
Geezatec's Avatar
Been useing a Compass Circle Cutter by X-acto for the last 15 years. Good enough to cut windshiald cooling hole and cutting wheel holes. Just score the circle a couple times or till it cuts through lexan and bend the circle out, and knock out lexon. Then sand out to finish. Take your time you may not have to sand it.
Cutting cooling holes follow the track rules. Or with ROAR Rules 1/3 of windsheild or 60mm Square or circle on road. 1/2 windsheild for Off-roaders
Geezatec is offline   Reply With Quote
SEO by vBSEO 3.5.0
