RDLogics Mongoose >
RDLogics Mongoose
RDLogics Mongoose
Old 05-08-2005, 09:15 PM
  #601
Guys .. Just bought my 710 ;-) .. i'm starting to build it.
I've been reading this forum, and can't say how proud i am in beign in the snake team ... planning to stick with it ;-)
I have a little question
Where i race, by the rules, we can only race in Rubber Tires..
Can I use a On-Way diff with it ??.. and how about the car setup ?? any recomendation for rubber tires !?
Thank you very much ....
Rodrigo Meira
RMeira is offline
Old 05-08-2005, 09:28 PM
  #602
wad
wad's Avatar
Rodrigo Meira
710??
I think that you are in a wrong thread!!
wad is offline
Old 05-08-2005, 11:10 PM
  #603
Nils... I would try the 47 or 46 tooth 2nd gear spur first... The 45t is alittle tall and you may not see the speed gain you're looking for... As for the 20t rear side and brake pulley gear, the rear belt will fit alittle snug, but should fit and work with no problems... Take a good look at everything and give it another try. The rear low friction belt should fit and work fine...
RC_Alan
rc_alan is offline
Old 05-09-2005, 01:40 PM
  #604
nils's Avatar
hi alan,wel i have the 20t pully,s on it turns but there is a lot of
tension on the belt,i hope it wil last a race.
as for the 46 2nd spur,then i can also use the normal black gears
what is the difrend,s between the standard and the s class spur,s
the standards are also in the size of 46t , 47t and 51t ore 50t.
and they are cheaper than s class gears.
nils is offline
Old 05-09-2005, 05:15 PM
  #605
Nils... The S-class gears are design to 1. allow your car to reach top speed quicker then before with the old stock gears and 2. also give you more gearing options... Before with the old G4 stock gears, you had a very small tuning window as far as gearing went... Now with the S-class gears, we are now able to have a quicker takeoff with the new 18t and 19t clutch gears and with the optional S-class spur gears, we're now able to obtain a higher top speed quicker then before... and just about any other 1/10 on-road nitro car on the market today... Also, You'll have to use the S-class 2-speed housing with the spur gears.. Hope the info helps...
RC_Alan
rc_alan is offline
Old 05-09-2005, 06:55 PM
  #606
CAN ANY 1 GIVE ME THE GEAR SET UP FOR THE GOOSE IM GOING TO USE 18T 25T 52T 45 NOT IN THIS ORDER OF COURSE
goosein LV is offline
Old 05-09-2005, 07:39 PM
  #607
Motorman's Avatar
thats pretty good for vegas, might try 24 and 25 depending on your engine
Motorman is offline
Old 05-10-2005, 05:16 AM
  #608
Default 4m
has anybody tried the 4m chasiss for the mongoose ? how much more duz it weight ?did it work better then stock 3m .
isuzuguy is offline
Old 05-10-2005, 07:53 AM
  #609
Registered User
xrcbuggy's Avatar
Hi guys,
I have plan to get this car, but I am reading there is a problem with belt rubbing in front? Is this problem corrected by RD logics?
Or do we have to some how leave with it?
xrcbuggy is offline
Old 05-10-2005, 07:57 AM
  #610
YBSLOW's Avatar
Originally posted by xrcbuggy
Hi guys,
I race for RD and I have never had the front belt rub.
YBSLOW is offline
Old 05-10-2005, 06:17 PM
  #611
charlesd's Avatar
I just finished my mongoose. In the manual for the stock set-up -- is it really 0 degrees ( toe-out )? It's written weird and i just wanted to make sure.
thanks
By the way -- the front belt does not rub anywhere on mine.
charlesd is offline
Old 05-10-2005, 06:41 PM
  #612
Regional Moderator
daniz24's Avatar
Yes, I believe front 0 and rear -2 toe in is a good start.
daniz24 is offline
Old 05-11-2005, 11:05 AM
  #613
Tabushi's Avatar
Guys,
Im ordering a couple of mongooses on my club this weekend ...
I heard that the servo selection can be a problem ... cause there is not much room for estandar servos on the chassis ...
I have 2 servos NIB, one Hitec 925 steering and one hitec 645 (throttle) and wonder if they will fit or i have to order new servos ... and in this case ... which ones !? ...
Tabushi is offline
Old 05-11-2005, 11:09 AM
  #614
Suspended
Jpilone's Avatar
save yourself the trouble and get a Futaba S9550 (very low profile digital servo)
Jpilone is offline
Old 05-11-2005, 11:30 AM
  #615
What are the specs on the Futaba 9550? i.e. torque and speed?
jnims29 is offline
