RDLogics Mongoose
#1907
Originally Posted by Car Breaker
I used to run the big S car, but I go back to Mongoose because it is just more comfortable to drive. people choose car not only base on what they drive well, sometime the reputable and parts supply count
still I like G4
still I like G4
#1908
hmmm
i hope ill be much better with 3rrr
#1909
RDLOGICS ARM SET
I am ordering parts for the upcoming season and have a question.
Does the Arm Set listed on RDLOGICS site (#502305) include both upper and lower arms left/right?
Doug
Doug
#1912
which servo.... ??
Hi all.
I've recently purchased a RDLogics Mongoose and it's almost fully assembled, but the problem I'm having is, I assumed I could use the servos off my Monster GT truck. However, when I tried to install it, I discovered it will not fit well. Apparently the server is too big/tall (the servo arm sticks out too much and the steering linkage is hitting the frame). Someone recommended to me that I look into a low profile servo. I looked around the internet some and it seems the low profile servos aren't very fast on response times.
Has anyone else had trouble fitting a standard size servo into their Mongoose?? Can anyone recommend a decent low profile servo? I'm not sure
how many Oz's of torque is recommended for my car so I'm having trouble determining the right servo for me. Do they make a metal gear, high speed (perferrable a .08 - .11/sec) low profile servo?? All the ones i've seen that claims to be high speed are .15 or .18/sec. I was hoping to find something better.
Anyways.. was hoping someone may have some good recommedations for me
#1914
Thanks heavy, I'll mess with it some more and see if I can your solution to work for me.
#1915
I tried your suggestion heavy and it seems to work prefect.
it's a close fit, but it works!
thanks again!
thanks again!
#1916
The Mongoose to partial G4S upgrade kit has been released. See G4S thread. We should have them in a couple weeks.
#1918
Guys, I need the 3 weight/shoes that go on the 30mm Centax Clutch on the Mongoose, but I can't find them anywhere, I did find those 3 shoes for the 30mm NTC3 Centax Clutch though, and they look identical, anyone know if those NTC3 centax clutch shoes work on the Mongoose Centax?
#1919
well i bought a new mongoose, except for having to shim the servo and reverse the ball it went together sweet. couldnt believe how fast it is with a little OS12. Took it to the track to set it up and couldnt believe the cornering diffrence between it and my old reflex. just dont see how an upgrade kit could make it any better. Best handling car ive driven so far.
