1/8 tyre truer adapter.
I have recently purchased the 3racing automatic tyre truer together with the adaptor to enable me to fit 1/8 wheels. I can't seem to get the adaptor to tighten to a sufficient level in order to stop it spinning on the truers shaft, if I tighten it anymore the bolt is going to sheer. The adaptor is made by 3racing so should work ok. The 1/10 scale adaptor that came with the truer works fine.
Does anyone know if the Hudy adaptor will fit as I'm not going to waste my time trying to get a replacment from 3racing as it was only $13.
Thanks.
Thanks.
Thanks. Can you confirm that they will all fit the 3racing truer? I'm guessing that it is a universal size?
The best if someone can measure the inner hole diameter of hudy 1/8 adaptor and compare it with the thickness diameter of the motor shaft.
I know hudy 1/8 adaptor will fit nicely into 1/8 rims, so that's not a problem.
Will the motor shaft fits into hudy adaptor ? that's i dont know.
Ofna = 3racing = same thing.
Arnt all truers a standard 8mm shaft?
Jim I see ya in the uk, comet rc sell a h.a.r.d. racing abor for bout 17 quid!
But hudy are the best to be honest
Cheers jas1, I'll check em out.
Thanks.
Thanks.
I had the exact same issue. What I did was use a pair of vice grips to help squeeze the arbor then tighten the 3mm screw at the same time. I agree it is a problem but this might get you going. I love the truer other than that.
In any case, I accidentally ruined the threads on the 3racing arbor and would like to know whether a Hudy one would fit?
thx!!
Yes I used hand held vice grips. I'm not sure if a Hudy arbor would fit or not. The diameter is probably the same, but I don't remember if it squeezes on or has a flat spot with a set screw. maybe someone can enlighten
Yes, the Hudy tire truer adapter will fit any brand tire truer!
here: http://kamikazercracing.com/proddeta...prod=HUD102362
solution
Hello Jim,
I have the 3racing tire truer and had the same problem.
I fixed it by just adding a bit more gap at the adapter with the dremel so I can now tighten it more.
