Old 06-20-2011, 09:34 PM   #1
Default Pats Precison Brakes for RC Bikes
Hey guys if you have an RC bike you will want these brakes. Pats brakes will lock the rear wheels up with the least amount of servo pull needed.
Use coupon code RCTech1 and receive 10% off!
This Brake Set will fit front or rear nitro or electric bikes. You can run single or dual sets on the front and rear. For nitro bikes we recomend dual front and single rear so you need 3 sets. For the electric bikes we recomend dual front sets. The more sets you buy the more you save. Complete with stainless steel cables and covers. These brakes will only fit the alloy one piece rims front and rear and rear only 3 piece rim. Will not fit the new 3 piece NF rim on the front. This is a single complete Aluminum kit for front or rear of Electric or Nitro Bikes. This is the Single Brake Set all 6061 T6 Aluminum with GRP pads (Same stuff circuit boards are made of) replaceable pads. Comes complete with Single Front or Rear Rotors with Fiberglass Pads, Calipers, Mounting Brackets, Nuts and Bolts and Stainless Cables with stainless steel covers This is a complete NEW brake system with replaceable Fiberglass Pads. The Brake Cables are constructed with a sheath consisting of wound stainless steel. The cable is 30lb breaking strain stainless stranded wire. These brakes do not need monster servo's the 3.3kg/cm servo's pulls the nitro and electric brakes just fine. Probably the most sought after brakes for RC Motorcycles in the World. Perfectly machined All T6 6061 Aluminum pieces for your RC Nitro Bike. We are proud to be offering these to our customers. Best possible braking money can buy period. Shipping is absolutly FREE on this item while supplies last. Only a limited number coming so if you ever wanted a set of Pat's Brakes nows your chance. Beautiful Workmanship! These brakes will only fit the one piece front and rear rims and the 3 piece rear Only of SF506 and SF509 ALL models.
Pats Precison Brakes for RC Bikes-hpim4261.jpg   Pats Precison Brakes for RC Bikes-pats-brakes-2-flyer.jpg
Gotnitro2 is offline   Reply With Quote
SEO by vBSEO 3.5.0
