-   Nitro On-Road (https://www.rctech.net/forum/nitro-road-3/)
-   -   Broken high speed needle? (https://www.rctech.net/forum/nitro-road/523173-broken-high-speed-needle.html)
Latrodectus27 06-13-2011 06:10 PM
I think my high speed/idle needle may be broken. I've tried adjusting it, and fiddling with it for awhile, and it doesn't do anything.
Suggestions?
GMartinez 06-13-2011 07:17 PM
Suggestions?
check the o rings they might be worn out & dismantle it look at the actual needle might be damaged good luck
JJBinks 06-17-2011 07:48 AM
Suggestions?
Along with checking the O-Ring, it may also help to take the needle out and and with and exacto knife gently scrape the needle to get any build up off of the needle as well as create a clean mor precise surface. I have done this in the past and it has made a difference
