2nd gear woes on my V-one RRR
After finally getting the centax clutch setup on my V-one RRR Shimo shimmed to perfection, I am now having issues getting 2nd gear to engage. I seem to be either too tight or too loose. I am sure to be adjusting them together evenly and I remove the clutch housing to do so to ensure I'm precise, not using the tiny adjustment hole.
For a brand new 2nd gear clutch and housing on a V-one RRR, what would be an optimum starting point from the adjusting screws all the way in? EG: how many full turns out from all the way in should I back them out as a starting point so I can work either looser or tighter from there?
Thanks!
Alex
Thanks!
Alex
Thanks!
Alex
Thanks!
Alex
Wow really? The manual said 3 full turns but even that seems too tight.
Just found out the inner bearing on my clutch bellhousing blew apart so I'll have to wait until Saturday to give it another try...
Thanks!
Alex
Thanks!
Alex
I followed the manual's suggestions and then tuned it from there it was only about 1/8 turn off on each screw for a flash w/ 17/22 56/60 for gearing.
Thanks!
Alex
Thanks!
Alex
Cool, thanks for the tips guys!
